CPP
" For the EL-8 they use factory original connectors to assure a proper fit" , good information thanks.I order a cable from them. Already received an e-mail from Chris that he sent the cable.... I should have it with a couple days. He assures me the cable is better than the factory cable, much more solid and thicker (and better sounding because of the materials they use). They also have higher level cables if your taste goes that way. For the EL-8 they use factory original connectors to assure a proper fit!
