Jack
2 and 4 on the tubes and 1 and 3 on the caps.
Not sure what you need that is in reality a problem with the MP-D2 but then I am not a hi-rez guy.
Maybe spdif/Optical to USB converter can help?If it can't do above PCM 96khz, and can't do DSD over coaxial/optical, a LOT of my musiclal library is unplayable, including many very important recordings.
JC
You would need a nice linear PSU with that too. Not sure f only an ifi iPower would be good enough Uptone audio has stuff too.http://www.sonore.us/microRendu.html
Would adding a microRendu help solve the problem? You could sell the Marantz player.
SoTM SMS200 is another option....both both of these need a NAS or other PC feeding them....which he has!
Take a look at the Auralic Aries Mini, especially used, the combo of it and the MP-D2 will get you within you budget. You can later add an internal HD to the Mini and transfer your files to the Aries.
Go for it!
I wonder how the MP-D2 compares to the Bryston BDA-3? Guess I need to order one........
Curious how they are going to be able to adapt the input buffer side to accept two different sounding series of DAC chips. To my ears the base sonic signature of the ESS and AKM chips is different and require different input designs to shine so we will see.
