Mike,
Thanks for posting this photo. ML's system is incredible. The Dart 458 monos must sound sublime. What brand of speakers are those? I've read that he is extremely happy with his Lampi SE GG with Elrog 300B's for DSD and his Trinity for PCM. A no holds barred system for sure.
Best,
Ken
Mike,
Best,
Ken
Alex,Hi Ken,
These are Evolution Acoustics MMSeven. Oh, AFAIK, Mike doesn't have the Trinity anymore.
I can only imagine how great Mike L's setup might sound, as we have a pair of the speakers Mike used before the Sevens, the Evolution MMthree, paired with darTZeel's integrated, and it's incredibly lifelike!
cheers,
alex
in January I had 7 new Furutech GTX-D NCP (R) duplex outlets and the Furutech frames and covers. that was another significant step up.
then this last week I added 9 sets of the new Furutech FI-50 NPC male and IEC plugs to each of my power cords. the final caper to the tuning process.
'NPC' stands for Nano Crystal Particles. basically the heat in the circuit triggers negative ions which clean up EMI/RFI and other noise. the 'agent' is tourmaline crystals which you would find in some hair dryers to reduce static.
anyway it really works.
I'm pretty damn happy.
Hello Mike,
I am hoping you can give me some insight on the Nano Plugs from Furutech.
I have purchased Furutech Nano cables to run from my Torus Wall Mount Transformer to 5 new GTX-D NCP(R) duplex outlets, frames and covers for installation in my new room. Also, all of my power cords are Furutech Nano Power Cables, however, they are terminated with the original (non NCP) Furutech FI-50 (R) male and IEC plugs.
So here is my question: Was the change from your original connectors to the NCP's a big step up in your incremental process? I appreciate these things can be marginal; nonetheless, I would greatly appreciate your view on whether changing the connectors will be significant (particularly since I have the Furutech Nano technology going all the way from the transformer to equipment).
Thank you very much in advance,
