Meitner MA-3 DAC
Currently using simaudio moon 390 for all in one roon digital solution. Looking to upgrade. Bartok is out of my reach. Is the MA3 definite upgrade in terms of sound quality? Inside of the unit looks pretty flimsy which erks me little.
Hi all,
I just upgraded from a PS Audio DirectStream to the MA3 and I couldn’t be happier. This DAC is so natural sounding, the music just flows.
For the other MA3 owners there has been a firmware upgrade so the latest version as of December 9, 2022 is
1.20-132:006
1.20 primarily adds a “bypass” function allowing the volume control to be fixed for use with an analog preamp.
Now back to listening. 😃
how do you install the firmware upgrade?
Well this is where they are a bit behind. You need a Windows PC/laptop and a USB to serial cable. There is an upgrade program that you have to get either from your dealer or Meitner support directly. The upgrade program will be packaged with the upgraded firmware.
You put the MA3 in to firmware upgrade mode by rebooting and then pressing the bottom light while it is flashing. Then run the program on the laptop, it will detect the MA3 and then start the upgrade. Full instructions come with the upgrade package.
I use a preamp so I upgraded for the volume bypass feature. There were no audio quality changes that I could notice. Support said they will be changing over to USB sticks in the future.
Recent MA3 review from December 2022. Audioshark won’t let me post links yet so here is the URL
//https://twitteringmachines.com/review-meitner-audio-ma3-integrated-d-a-converter//
Hello folks,
A friend brought me a MA-3 to try at home.
I just never heard digital sounding so good.
Absolutely stunning natural sound, with lifelike dynamics and image and absolutely zero digital artefacts / aggressive sounds.
Magical.
Envoyé de mon iPhone en utilisant Tapatalk
Hi all, for the Meitner MA3 owners there is a Conversdigital network card firmware update available. The latest version is now emmlabs_1cup_Bdmrsv v3.9.31. The prior version was 3.9.28.
You can apply this update using the mconnectControl HD app.
This is not the same as the DAC firmware which you can get to from the menus on the DAC. It’s only for the 3rd party network interface which is made by Conversdigital.
According to Meitner support this upgrade addresses Tidal and Qobuz api changes. No changes related to sound quality.
I’m not aware of any other way. Maybe make sure you have the latest mControlHD app. My icon looks like this. Lastly, perhaps try again at a later time. Perhaps their server is down.
