Bobvin
- Jun 25, 2013
From what I can see Jim Smith first determines the seating position that'll be out of room nodes, then places speakers for maximum musicality. My Wilson setup guy has not done this step in the past, but he is still able to get amazing sound in any room. Since I've done the big remodel, I have several feet fore/aft that I can move the listening position and want to avoid nodal peaks. Obviously half-way between the front and rear wall would not be the correct spot! :exciting:
In my room I have computer/DAC. The computer is a custom built small profile fanless design with SSHD. There is no room to add a sound card, I am forced to use the onboard Realtek drivers with a microphone. The computer has a ASUS Gryphon Z97 Socket 1150 Intel mobo.
Can I just get a calibrated USB microphone, load software like Room EQ Wizard, play some pink noise or test frequencies, and be good to go for taking basic measurements? (Most of what I've read says I'd need a dedicated soundcard?) There would of course be some assigning of inputs to get things right, yes?
