Marten Coltrane Supreme II
wizard
Here's a sneak peak of the new Coltrane Supreme II.
Releases at CES 2014.
Price €360,000
Nice! Thanks for posting! I have 1 friend with a pair on order and a 2nd who is considering moving from Supreme 1 to 2. Have you heard it?
See the attached PDF file.
Thank you Bill. ...I checked everywhere and couldn't find the exact replicate; all the other pictures were different, they did not have that silver/gold front plate surrounding the tweeter, the mid-tweet and midrange drivers (3).
And yes, they are roughly $0.5 million USA dollars for the pair. ...Or $250,000 each (for the center channel).
Ok.... This is my next speakers !!! :D
TECHNICAL SPECIFICATIONS
Frequency range / 18-100000 Hz +-2dB
Power rating / 500 W
Sensitivity / 91 dB / 1 m / 2.83V
Impedance / 6 ohm (3.2 Ohm min)
Type / 5-way
Drive units /6x11” passive sandwish, 7x8” alu sandwish, 1x5” ceramic, 1x2” diamond,1x0.75” diamond
Crossover frequency / first order: 120, 450, 3500 & 8000 Hz
Terminals /WBT Nextgen bi-wiring
Internal wiring / Jorma Design Statement
Cabinet / 25mm:s carbon fibre laminate sides, 70mm solid laminated wood front, back, top and bottom
Stands / Polished stainless steel with Black Diamond Racing pucks and cones
Dimensions WxHxD /
54 x 200 x 59 (21.2 x 78.8 x 23.2”)
Net weight / 230 Kg (507 lbs)
