Myles B. Astor
- Apr 5, 2013
I think that many of you should visit the Magico factory actually see the elaborate process that goes into building a Q7 (or any model of Magico--or any top flight speaker for that matter nowadays). I really think many audiophiles think these are some $400 DIY speaker kit you buy online where you bolt six pieces of wood together, glue a xover in, solder some connections, screw some drivers in and presto you have sound.
Just for starters, a 1000 parts go into making one Q7 speaker. The baffle is hardly JUST bolted on. Xovers and drivers are built and tested and matched. You have a whole new front baffle being machined, anodized, etc. You hardly make a couple of cuts like on a piece of wood and you have a baffle. There is an elaborate CRC cutting and finishing process. Oh and the anodizing rejection rate for the front baffles, even for the BEST company Magico could find--and they tried quite a few--is 30 pct. Alon hates the anodizing process. Then you want to make sure the baffle actually matches color wise the existing speaker. Then all the pieces are torqued and tensioned to control the cabinet's and driver's resonances. Those waterfall cabinet resonance charts that you see from Martin Colloms, etc. don't happen by accident.
After the speaker is assembled, it then goes through a lengthy break-in process. Then the speaker goes through an elaborate Q/C testing process that only four other companies in the world use. I won't name who doesn't use this system but two of the others are B&W and KEF IIRC. Then the speakers are brought into Magico's custom built listening room and checked before shipping (I won't go into the shipping process.)
So you add up the hours and the number of people involved and it's very costly. And me thinks that people here think that Alon should eat all this time--that also remember either he has to hire new people to do--or it takes away from his existing staff's time to build all his speaker models.
And the alternative? You sell your existing speaker for 1/2 price at best and then reinvest that plus the difference into a new one. As I see it, current owners are getting a good deal from Magico. Sure it's costly but if you have the money to buy a Q7, I think it's a different matter.
After all, updates build customer loyalty but very few come at no cost. You buy a Linn upgrade for instance and you take your turntable to the dealer and buy the upgrade kit/parts and pay the tech's time, which ain't cheap, to install the upgrade. So the same goes for Magico. I really don't see why they should take a loss on the upgrade when I don't see anyone else in the industry doing that.
