M
Fantastic.
Are you going to have Q-Sub 15s on display with the M3s?
Totally irrelevant review. How many are going to partner a Magico sub with anything other than a Magico speaker?
He should have replaced the JL subs in his MProject system with the Q Subs and then reported.
The nice thing about Mike's site Audioshark is that many of the guys that comment on equipment are actually the guys that have the components of which they pass opinions. This applies to this thread and numerous others.
I await to hear Mike's client's comments about the pairing.
It might actually interest me into further investigation with my D5.1's
Thanks Mike for fostering this environment.
Hi Leroy,
I was actually wondering if you might be Mike's client.![]()
Do you feel the D-5.1's in your listening room might benefit from the additional bass provided by Magico's subwoofers or do you feel you already have sufficient bass?
As for my system, I was recently asked if I would purchase the Vandersteen subwoofers. I explained that my listening room is not that large (21' x 17') and the Vandy 7 MkII's internal powered subwoofers already provided more than sufficient bass for my room. Anything additional would just be excessive.
Best,
Ken
Hi Ken,
I don't mean to answer for Le Roy, but my understanding is that the benefit of successfully integrating a sub is not so much about adding more bass; but also and perhaps even more importantly, it's about providing a more solid foundation to better sort out the midrange and upper frequencies in order to let them shine in an even more coherent way.
I'm certainly tempted to look into the Magico sub for my system.
I find that in a properly integrated sub system with full range speakers, the only way you know the sub is on is to turn it off and the mid range falls flat. You don't really loose bass, unless you are listening to techno or pipe organ music.
I also find that the size of room has NOTHING to do with needing subs. In fact, smaller rooms often need subs more than larger rooms because the bass doesn't have the room to fill up the room because of the large wavelengths - damn physics.
I'll be happy to report back once the Q-15s get here and broken in. I loved the Wilson Watch Dog subs that I had but then sold because I mistakenly thought that the D5s wouldn't need subs. Stupid move on my part. I really liked the Q-15s that I heard at Magico so much I decided to bite the bullet and order a pair. I've been using a pair of REL Gibraltar G2s and they are good, but no match for the Wilsons that I had and soon to have Q-15s.
I also can't in good conscience recommend anybody spending this kind of money for subs. It's crazy!!!! Only if you are going for that last 5%, a great sub will get you 4% of the last 5%.
Thanks Jock! Do you think you'll purchase the JL Audio CR-1 outboard analog subwoofer crossover or do you have something else planned?
Ken
