A streamer with SFP and a good power supply. Smart.
MSRP for USA?
Did some googling, and it appears to be a mystery.
$5000. $2500 CHEAPER than the U1. [emoji848]
MSRP for USA?
I've never listened to a U1, nor owned a Lumin until this one. But I will say I never imagined that a digital streamer could make my system sound this damn good. I've demo'd an iFi Neo Stream, Sonore opticalModule and used my PS Audio DS DAC w/Bridge II card for nearly 2 years. This Lumin is far beyond any of those. I honestly (and arrogantly) thought my converted optical LAN was about as quiet as a LAN could be since neither of the other streamers bettered my PSA Bridge. Boy, was I wrong. I'm using my computer DAC to boot. An Ayre Codex. I can't imagine my digital system sounding even better when Ayre finishes building my QX-5 Twenty [emoji445][emoji444] This U2 is simply fantastic.$5000. $2500 CHEAPER than the U1. [emoji848]
I imagine you are right. Esoteric is top level stuff. I know the case amounts for some of the cost difference, but I can't imagine the whole $2k+. But the obsessive side of me passed on a U1 to wait/find a unit with an SFP Cage. When I first heard about the U2, I knew I had to order one right away. I just couldn't fathom wasting all of the effort and expense to convert my LAN to fiber, only to buy a streamer that would only accept copper. It may have cost me a little sound quality (not sure I'll ever know for certain), but I feel better with fiber all the way through.U1 forms the guts of the Esoteric network transport in N-01 (and N-03T) which I am very familiar with. I thought the Esoteric U1 implementation sounded outstanding. For the U2 to be better is hard to imagine. It would have to be getting close to Esoteric disc transport performance.
Sent from my SM-G998U using Tapatalk
I got my U2 yesterday. Breaking it in now. I did downsample DSD 256 to 128 and I can now play DSD 256 files.
There is a setting in the Lumin to enable LEEDH and also set a "maximum" output level (as a safety).
Once you enable it you can control the volume from your tablet/I-phone.
The Big Hattor is no longer needed in the chain.
However you can leave it in the system if desired, just turn the volume all or most of the way up.
Using LEEDH, the Lumin is now doing duty as a streamer and volume control.
Works great and sounds good.
If I'm not mistaken, your DAC internally upsamples to DSD512. In view of this, I suggest you compare conversion to DSD128 against conversion to PCM 352.8kHz, see which sounds better to you for your DAC in your setup.
so ... without passive preamp setup wil be sfp- U2- usb - DAC Rockna and U2 - XLR power amp?
