thingswelike
- Jan 9, 2014
No, Black and Silver are the same price on the U1 MINI and the D2Is is there an up charge for the black finish on Lumin products?
Hi WK, I’m reading this with great interest as I’m having some connectivity issues with my Cary Audio DAC200ts. The issues are:
1) I get a loud distorted sound and hiss when I switch from DSD 2.8 to 24/192 PCM/WAV. It persists on even if I try to any other WAV files of say 16/44.1.
2) There are instances where I can’t get it to start playing WAV files from cold and I have to select a DSD file first.
3) if the hissing issue mentioned above doesn’t happen, I get a crackle switching between formats.
4) There were instances where my DAC couldn’t detect the U1 mini and I had to reboot
I was using Jriver on my Mac previously as I can always set a silent delay during the handshake to avoid the loud crackle.
On the broader side, the app (IOS) seem to take a while to detect the Lumin as well as refreshing the file listing when changing folders. I also can’t seem to have my music sorted by album, genre and artist but could only find the, by folders.
Would appreciate it if you can assist as it sounds wonderful when it is working.
Many thanks,
SM
Please try a different USB cable for the DAC issues, and power cycle the DAC first, then power cycle the U1 MINI. If that does not work, use AES connection instead - with some DAC it may even sound better than USB.
Please install the free MinimServer to a NAS or computer, and use that as the music library instead of USB storage. This will fix the slow browsing and enable the various view options.
All my DSD files has metadata on artist, album etc. Although WAV files inherently doesn’t carry metadata but I’m able to use Jriver to enter manually. It shows on my AK380 as well as on my Sony Hap-z1es.
Will try the miniMserver route on the NAS. However metadata from my USB hdd doesn’t show up in the app when browsing but I can only see it if I depress on the track for a window to appear.
So I'm one week in with my Lumin U1 Mini, and it's already sounding great connected to a Qutest DAC. I upgraded from a D1 which didn't quite do it for me as a pure transport (I've found that in my setup Qutest seems a little sensitive to RFI when using the spdif BNC input).
I've also used SOTM sms200 in my current setup, which sounded great but didn't have the right level of usability (I use local NAS, Tidal and Spotify), where the Lumin OS and app makes for a great UX. The U1 mini is opening out nicely, and I'm hoping there's even more to come over the next few weeks.
