Lumin U1
Thanks for quick update, @wklie! I totally agree with you, Devialet should be ok with DSD regardless of with connection. But; when reading the specs of 250 Pro Expert on Devialet's own site, the following comes up:
[h=3]SUPPORTED FORMATS[/h]Up to 32bits / 192kHz PCM (USB)
Up to 24bits / 192kHz PCM (AIR®, UPnP, AES/EBU, Coaxial)
Up to 24bits / 96kHz PCM (Optical)
Up to 1bit / 3.072000MHz DSD64 (USB, Coaxial)
That was the main reason for my questions :)
These are almost contradictory, but I'd believe the text. Please test AES and let me know.
Today, I got confirmation from Devialet support. You're absolutely right, of course, @wklie:) "Our AES/EBU input indeed supports DoP streams".
I just have to buy an AES cable and test:) Let you know how it goes.
@wklie,
My Lumin U1 is now connected to my Devialet with a Weiss AES/EBU cable, playing DSD. The Devialet shows DSD64 in its display. Soundquality seems to be great.
Great! Please burn in the Lumin with repeat playback of playlist 7x24. Then you can compare AES against USB. When using AES or other SPDIF outputs, USB must be disconnected first.
I have now teste back and forward, changing between Weiss AES/Heimdall2 USB/Synergistic Research Galileo USB, always disconnecting the USB when listening with AES. The AES always sounds better than USB in my setup, with more transparency, dynamic and more defined bass.
Thanks for all your help regarding this matter, @wklie!
I think to improve the performance of Lumin U1 and replace the power supply. My choice of Paul Hynes SR5 or Clones Audio Power Station Deluxe. Does anyone have any comparison experience or any thoughts?
Please consider the official X1 power supply upgrade for U1.
If you wish to have someone custom make a LPS for you, please note the special DC connector.
Hi All.
Here is how Lumin App looks
after the upgrade to Android 10 of my Nokia 9 . Any idea?
W[FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]hat is the list price for the X1 power supply upgrade ?[/FONT]
Hi Peter, new to this forum and considering the U1 as my transport streamer. Reading the threads with the X1 PSU upgrade as a significant improvement, can’t Lumin offer the optional PSU upgrade at purchase so that the purchaser won’t have an extra PSU on hand and perhaps a price reduction for the trade in?
Thanks
Andre
Hi,
I have a question, I have a U1 connected to EMM Lab dac versus usb cable, and xlr cable connected from emm dac to new active speaker since there is no volume control on the EMM dac.
Can I use the U1 for volume control? if yes what setting should I use?
Thanks
Welcome to the forum
Thanks
Andre
Thank you Joe, been joining this forum for 3 years but never post only do reading and research.
Thanks
Yes.
Enable Volume Control and Leedh Processing Volume in Lumin app for U1.
Turn down the volume before playback.
Hi,
I pulled the trigger on the upgraded power supply for my U1. It’s now been about a month and it is fully run in. In short, the upgrade is unbelievable- honest to God I had not idea a power supply upgrade will throw such results. I can clearly hear more information, with a better soundstage which is separated incredibly well. And oh the bass! The delineation of the bass lines is uncanny! Anyway, I will stop here as it’s beginning to get too hyperbolic lest people should wonder whether I am being sincere. But yes, truly special imo.
i would recommend anyone sitting on the fence to take the plunge. Though expensive, it’s worth it
cheers
sujay
Same here, truly fantastic, especially the bass region. Fitted with SR Purple fuse and will also try SR Orange and Blue. Sujay's description is so true. It's worth the 3k CAD$. Cables and such may not give you this enjoyment.
If I can find a replacement DC cable 0.5 metres long since my XI and U1 are side by side. I prefer non-silver since the AudioSensibilty cables generate a presentation unsuited in my system.
