Lumin M1 Review
Thank you. It is better than AirPlay. And the machine is getting better by the hour. Now I'm wondering what are appropriate speakers to pair it with.
Anyone know , or want to guess, how the M1 would pair with KEF LS 50's?
I found this from Stereophile:
The figure above shows that the speaker rated at nominal 8 ohm measures down to roughly 4 ohm (3.2 ohm from web site), which M1 is capable of (100W @ 4ohm, 60W @ 8ohm). The LS50 requires a 25W-100W amplifier. In terms of figures only I guess they match.
Hi -
The current US price (per May 2016 price list) for the M1 is $2,300.
We have one, it's a very cool piece!!!
Cheers!
Mike Kay
Lumin M1 will be available in black. The volume knob in black looks better than in silver.
No, not directly supported. However, for 2 channel setup you don't need line level subwoofer output if you use a high level input such as the one found in REL subwoofer (that I use). That's the optimal input for REL subwoofer anyway.
Peter,
Does the M1 fully render MQA tracks via TIDAL, including Studio Authentication identification?
Yes, M1 is MQA compliant and fully decode / render MQA, including MQA Studio authentication.
