Dear All
We are a couple of audiophile friends here in Buenos Aires with Lumin A1 (me) / X1 (Andyk) / T2 (Sergio) and regretfully we are facing some problems... from time to time.. not all days.
The point is that we can not select "Albums" or "Songs" from Tidal
We can see Tidal albums on the Lumin App but we are not able to select/listen to any of them.
If we tap on "Album" we can enter and see the "List of songs" but it is impossible to select and listen any of them.
On the other hand if we look at the left side of the Lumin App on the "Last listen songs" we can select a song and play it.. but if we look for the same album or song on Tidal and try to listen it is impossible.
We have already plugged and unplugger PSU, Deleted and Re Installed Lumin App and also Tidal app.. Reset the Wi Fi Modem..etc.etc.. regretfully with no success.
IS there any recomendation..?
Are you facing this kind of problems too sometime..?
Any help will be appreciated.
Many thanks,
Fernando
Many thanks,
Fernando
