shadowlight
- Aug 27, 2015
Some questions
1) Any additional information on the LAN setup? Is it based on x86 or Arm product line? Does it pull the signal directly from the board via i2s or is it pulling data via USB? Assuming it is running Linux based OS to support Roon. I am hoping that it trickle downs to existing DAC's
2) Any cost mentioned on the 300b tubes? How did they sound compared to regular 300b or other tubes if changes were made?
3) The rotary switch that Lukasz mentioned for tube selection? Did he mentioned that tubes not labeled on the switch which are currently listed as supported in B7/GG still going to be supported? If yes, hopefully there would be some kind of document which says which settings to use for tubes not listed.
4) How did the DAC and amp sound?
Question for Mike. What are the diffuser used?
Thx
Thx
