What is the maximum power that a pair/channel could output? Obviously it would not be good to run them full out. What is a good design max?
Dear Dizzie, Here is the answer to the question you asked. :heart::heart: Dizzie
From the Tungsol website:
With a massive plate dissipation of 70 watts, the Tung-Sol KT150 is the most powerful octal beam tetrode ever produced. A pair of KT150s can allow an amplifier with a power output approaching 300 watts to be built.
The Tung-Sol KT150 glass envelope is a special egg shaped balloon that was developed to improve thermal dissipation and maintain a superior vacuum for the best sound. The fact that the glass envelope has no flat sides means the Tung-Sol KT150 has no problems with microphonics.
Were the Epsilon's designed with the KT150 specs or were they Kt88/120 amps that are ok to use KT150's?
Lastly, how do you find their sound? How is the noise level?
I think this is somewhat misleading in that the "approaching" 300 watts is the combined power of the two channels and that would be at the maximum plate dissipation rating which is not how you want to run tubes. The Quicksilver MS-190 ran the EL-34 tubes at the maximum plate dissipation rating of 25 watts. The real, no BS Mullard EL-34 tubes that Mike designed the MS-190 for could take that all day long. Once the real Mullard EL-34s were gone, I couldn't keep my MS-190 running with Russian EL-34s. It just ate them.
You mentioned Quicksilver as I did in another post. Sure their not "pretty", Their not high tech looking but Mike's amps which I have owned many do what their supposed to do. The V4's 170 watts into 4 or 8 ohms using Tungsol KT150s.
Those tubes are not KT150s. :huh:
Has anyone directly compared KT120's to KT150's? I heard ARC 75 with KT120 and then KT150 and it was better. The CAT with KT120 to KT150 was another reportedly nice change. Anyone prefer the KT120?
And where does the KT88 fit into this mix?
And yes, we all know the tube isn't the ultimate deciding factor, but I'm wondering if we can derive any generalities from the various KT tubes.
Mike, I agree with your assessment regarding KT120s vs KT150s on the Ref 75. The KT150s are definitely better in all areas. Too bad they are hidden. I think they look the best of all the common power tubes.
To me the KT-88's are a swiss knife, they do everything but nothing stands out or leaps to the fore of a shining quality that they have. After a while I get bored & experience a mediocre feeling from the experience. For me there is just something about them that is too smooth/linear. The KT-120 tubes really impressed me & when I heard the KT 150's I just thought they did everything the 120's did but just a touch better & almost with an effortless style, speed, bass,delivery, love them.
