Excited by the Scintilla the previous weekend, I visited Henk since I had one day off for Easter.
I have now chosen the Scintilla over the Duetta and the Diva. So that leaves me with a Scintilla and a horn choice that I will close off in June
http://zero-distortion.org/apogee_duetta_scintilla/
So you prefer the direct drive ribbons , i do too , cant get mine with the traces to sound the same , the 1 ohm does roast amplifiers and will limit your amplifier choices. The Krells are really good at 1 ohm , The FPB series not as happy as the older series , but much better in the top end. Best results for me was with a modded KSA 200. Regarding toobs, the BAT mono and VAC mono has 1 ohm taps , extensive conversation with VAC suggest their i200 mono's have no issues but its only 200/200 ..
What about the FR vs Scinnie ... ??
What do you think of these measurements at 1 ohm?
http://www.stereophile.com/content/symphonic-line-kraft-400-monoblock-power-amplifier-measurements
Try the stages Norman and Joe Manley Speakers were originally his father's setup ...
@Bonzo
The stages are better than you give credit and actually measure better than the others , very good in small rooms and only fails due to the smaller sweet spot and height sensitivity.
IMO, The mini grands were the sweet spot of them all and a favorite ..
Regards
There is a gent here in Brooksville that does Apogee restorations. Are there others?
Ah, I didn't catch that gent was the restorer. Yes, giving shipping costs etc, that would make the most sense.Yes I would get them restored from Henk in Holland.
Well, I would say "aspects" of realism. Having heard innumerable panels and horns, yes, each has their very favorable aspects of realism, but are quite different in how they interact with real rooms and sound. A bi-directional line source and multi-point source highly uni-directional source, illuminate the room and have summed responses in the mid to far field that are far more different than similar.In the writeup I posted exactly how I think both systems do realism using different approaches.
