was reading about this today. very interesting. im my time with vpi tables ive run , jmw 9t, 9s, 10, 10.5, 12.5, and classic arms and ive had a few extra armtubes . the most expensive was about $1200 for an extra armtube for the 12.5 arm on my tnt4. this armtube is $2500, yikes!!! can get an entire really nice tonearm for that. but it is pretty cool technology, id wonder how it was sound wise as compared to the regular s/s and alum arms. they have the counterweight suggestions for lyra cartridges below. not sure youd be able to run a heavy benz lp-s with this, but probably the aluminum lp would be ok.
yes that was a hint for you vpi owners!!! someone here needs to get one of these and test it out for us!!! :snicker:
VPI – JMW-3D
The VPI JMW 3-D
The arm looks like a traditional VPI Unipivot arm, except it's made in a 3D printer. The material is basically epoxy, which forms a rigid, lightweight, structure with good insulation properties. Epoxy is non-crystalline which impedes the transfer of vibration, so it’s the perfect material for tone arms. The shape of the tone arm shaft also adds rigidity to the structure and further prevents the transmission of surface vibrations. The result is a low resonance lightweight tone arm.
This tonearm is backwards compatible and will fit on all past and current VPI Turntables. It will be printed in 10 and 12 inch.
JMW 3D compatibility as of May 5/16/13:
Classic 1
Classic 2
Classic 3
Classic 4 (secondary arm only)
Counterweight Suggestions for the JMW 3D 10"
For Titan, Etna and Atlas the 180gm is ideal!
For the Delos and Kleos 160gm is the one.
For the lightweight Skala, 120gm is ideal
VPI – JMW-3D
The VPI JMW 3-D
Classic 1
Classic 2
Classic 3
