hifinutt
use iso pucks under a number of speakers , always an improvement . also the rubber standard ones protect the veneer
P1060718 by https://www.flickr.com/photos/158267783@N02/, on Flickr
I’m not sure what took me so long to pull the trigger on the Gaia’s!
Same here, can't handle thin and hyper detailed.
The biggest drawback with the Gaia's is the installation method which creates an adjustment issue. There is no easy way to do micro-adjustments in height as the logo of the footer has to be facing out at all times. One full rotation of the threads is all you get. I use lasers to measure and level my speakers so this adjustment is important to me. Still trying to figure out exactly how I'm going to manage this, but I've got a few ideas. Any suggestions would be appreciated.
I was told, and videos say the logo can face forward or to the rear so you have Half turn adjustment. Oddly, I installed mine all the way before flipping the boxes over during unpacking, and they are sitting on thick carpet without spikes. I threw a level on them and they appear to be dead square.
I have no idea of the benefits since I installed the footers from the start. I do not have thin or overly detailed bass, just the opposite. I plan sometime to put them up on my granite slabs from my Dyns, but they are slightly smaller than needed.
Would also not hesitate to try the Arya 'RevOpods'.i put them under my Tidal 'Contriva Diacera-SE and the improvement is amazing. Mine on dense carpet.Great mechanism to raise and lower the devices.Much easier to install than the Gaias.
There are two locking nuts on each Gaia. I used the top one to adjust height on my speaker. That is the proper procedure as far as I know. One doesn't need to spin the footer at all.
Hi,
This product (Arya RevOpods) looks very well engineered. Thanks for bringing it to my attention. What is the cost of a set of footers for a pair of loudspeakers and do we have dealers in the US?
Thanks,
Anshul
Morgan - and others having difficulty adjusting Gaias.
You're right, it is tricky particularly as the locking nuts provided are pretty useless. There's an easy alternative that makes the job of aligning the logo forward dead easy.
Ditch the locking nuts unless you want to raise the speakers or add a tilt. Then use one of these 3 alternatives all of which allow the Gaias to be progressively tightened against a load, so you just stop tightening when the logo faces forward.
Wavy spring washers M8 or whatever size thread you use - A4 MARINE GRADE STAINLESS STEEL WAVE WAVY SPRING CRINKLE WASHERS METRIC M1.6-M20 | eBay
Neoprene washers that squash as the Gaias are tightened - BLACK FLAT THICK NEOPRENE RUBBER WASHERS - M3 M4 M5 M6 M8 M10 M12 M16 M20 | eBay
Felt washers that squash down.
I use the wavy spring washers - a couple on each thread gives at least one full turn of adjustment to keep the Gaias secure.
Peter
If I get you right you are saying that the supplied threads are too long for your Blades ie the depth of thread into your speaker's bass panel plus the depth into the Gaias leaves too much thread to be filled with the wavy washers I suggested. OK, just leave the supplied locking nuts on the threads plus the wavy washers or other compressible washers. Or have I got it wrong?Thanks for this suggestion. The problem that I face with my Blades is that there is only about 1/2" of thread into the speaker and the opening is capped so that I have very little room to work with. I would have to cut down the thread adapter to use this method as I can't thread the adapter all the way through the base of the speaker. There is only a small hole above the stem of the footer that allows for an allen wrench to enter to adjust the supplied spikes.
Being able to have the logo face to the rear should provide the adjustability I need in order to properly level the speakers. Should be all set.
Once the thread adapter is tightened into the footer, the only way to adjust height is to rotate the footer. The upper lock nut is there to lock the position into place once finalized. Are you not tightening the thread adapter into the footer?
