HELP, They're installing aluminum wires outside
JDC
(I'm worried about my stereo)
I live in south Florida, prone to occasional hurricanes. The power company, Florida Power and Light, is installing underground lines now in our neighborhood. They're a year late from when they said that it would be done, but they were here today working on it. We have 3-phase electricity, whatever that means. I'm clueless. We're the oldest and only house on the street that has the 3-phase. I was out there speaking with the guys and noticed the bare wire. I figured it wasn't silver... Every neighbor is also getting aluminum.
One good thing (maybe) is that they installed two new transformers by the driveway to connect the aluminum to the house, the only one on the street, so they could accommodate our 'three-way', so I figure I might be getting some relatively clean and good powerful power.
In my googling today I learned that:
- aluminum is about 60% as conductive as copper
- but with thicker gauges it can be similar
- aluminum oxidizes easier/less that copper
- the long power lines of our nation's power grids use aluminum over the miles for it's light weight and cost effectiveness.
My question in short: Should I be worried?
Why worry? It will not change anything.
No; aluminum mains are quite common. Its only weakness is its lack of malleability where repeated flexing will cause a break. This was a problem during the mid 70s copper shortage when aluminum was used in wall and often shorted at the panel or receptacles where the heat expansion at the fittings caused movement and arcing.
It’s unusual you have 3 phase into your house. All power distribution in the US is three phase and transformers on the pole or the street tap off two of the three phase legs and step down to the 120/240V split phase service in most residential properties.
Good news if the transformer is all yours with no other houses on it you have the best bet for clean power coming in.
  • Like
Reactions: JDC
