Would like to try out some amps around a Lumin X1 and Scansonic MB3.5 B. Will do my best to describe my constraints and preferences. Just looking for any subjective thoughts or input, if you're game.
On the list for possible rotating in:
Enleum 23r, Bakoon 41/51, NAD M23, T+A Amp 200, Ayre VX-R, Soulution 311, something Gryphon
(yeah, I suspect these may be very different from each other and some may be challenging to find in budget)
- Budget ~<$10k, new or used.
- Form factor is important. Has to be less than 18" deep, around 16" is ideal (width/height don't matter as much). Weight <80 max, prefer <60.
- Prefer a stereo amp in one chassis, but would consider monoblocks.
- Not looking for an integrated, but would consider if all else is right. Simpler the better. Lumin out to the amp; I have no other input needs.
- I listen mostly low-mid volumes, sitting about 9 feet from the front plane of the speakers. Mostly jazz, classic rock, classical (baroque, orchestral, piano), alt-country, world/eclectic. Nothing too heavy really, beyond the occasional Sabbath or Rush disc.
- I like part of @joeinid 's description of the Enleum: "an open, lit from within sound". Also: big soundstage, placement/separation precision and air, speed, a good thwack of a drum hit, vocals like they're in the room. Organic and musical.
