Rayooo
- Apr 5, 2013
Another brutally hot day out here in NW NJ....
around 100DegF at the moment. :heart:
Along with the heat, it appears the power company has jacked up the voltage.
I noticed yesterday the amber warning light on the Furman was illuminated, and the readout saying 125VAC.
'Fluke meter confirmed it, today, as yesterday, at some point the Furman decided it was too high, and kicked off the power to the hifi. I forget what the threshold is, but, I saw the readout at one point saying 127VAC, 'so it must be around that.
With the power off, I decided once again to try DAC-Direct. Since it's all the rage these days.. I'd tried this prior, and was impressed at how well things sounded.
So I disconnected the GAT, hooked DAC (D-07X) direct to amps, and away I went... as before, 'sounds good, very good.
I picked a few good recordings to listen to, had a quick listen, then popped the GAT back in.
Well, the GAT wins another round. Whatever the GAT does, coloration, distortion, abomination or dictation, it adds a nice "pleasure layer" to the sound... it's staying, at least until I change out DACs again.
AC at the moment is 122volts, not bad.. 1000 air conditioners running will drop at least 5 volts I suspect. :bonkers:
