I ran a dedicated 20 amp line to the outlet behind my system and it was a worthwhile investment. To take it to the next level though I bought PS Audio P3 Power Plant which is a power regenerator. It takes the AC that's coming in from the outlet, converts it to DC and then reconverts it to an ultra-clean, hash free AC signal that makes a huge improvement in dynamics, bass and the size of the soundstage.
You bring up a good point! If I had purchased the P3 prior to installing the dedicated line, I may still have hired an electrician but only to up the amperage at the outlet from 15 to 20 amps.sounds like an effective power strategy.
just thinking out loud here on an unfamiliar subject... if one uses a power regenerator like the ps audio p3, would not that make whatever power distribution chain coming before it irrelevant? sort of like the power equivalent of optical isolation?
Don't confuse a regenerator with the many filter type products on the market; they are very different animals.My belief says many times regeneration, filters etc are band aids for issues in your home electeical system.
I know exactly what a regenerator is. Its a ac to dc inverter feeding a battery bank followed by another dc to ac inverter. Its limited by the ability of the dc to ac inverter.
Solar systems are also dc to ac inverters. Never put solar on your house if you want good audio. They are very noisy. I have never heard a P10. I assume PS Audio uses a better inverter than Sonnyboy or Outback or one of the other commercially available ones out there. Batteries also make noise. If they were so good, many phono stages, DAC, Servers etc would use them. They don't for a reason. Even Sutherland uses wall power in place of a bunch of DC batteries now.
But still, you should not need any regenerators or filters. You probably have a few other issues in the power distribution at your house. And your local electrician won't find them. I built up Eds house, then his plant electricians, very skilled guys, showed up, did not understand why I did what I did and tore my work out. I showed back up and put meters in his gear and proved what I was doing was valid. The sound improved when I was done.
There could be situations where you need a something or another because you have issues out of your control. Before I invested in anythig like a power filter or regenerator, I would think about what is feeding the rack. What is injecting noise into your audio.
Rather than theorizing how well the PS Audio regenerators work, you can order one and try it out in you own system for free. They will pay the shipping back to Colorado if you're not satisfied with the results. Listen for yourself instead of coming up with reasons why there shouldn't be an improvement.FWIW, Pure Power is a battery regenerator. Not sure a PS Audio P10 is.
It does not seem to have batteries. .
Some areas of the US have special regulations, Chicago is at the top of the list.i am in the US -- there is access to everything from the mechanical room in the basement which is below the listening room, so it would be a fairly easy thing to have done.
Save the regenerators for people that have real strange AC power companies or poorly designed audiophile equipment that can't deal with common AC power.Rather than theorizing how well the PS Audio regenerators work, you can order one and try it out in you own system for free. They will pay the shipping back to Colorado if you're not satisfied with the results. Listen for yourself instead of coming up with reasons why there shouldn't be an improvement.
