Then there is the filter box that treats DSD like analog and only does LPF, which TED Smith agrees is the conceptually purest way to go.
My pal with a Trinity Dac and a GG Dac has been shocked to find out that Jarred was correct. The same channel Classics music sound better in DSD than it does in hiRes PCM, BECAUSE IT WAS RECORDED IN DSD.
To my mind, you play back in the most native format you can, so PCM as PCM and DSD/Analog transfers as DSD. You also play to the strength of your better conversion engine, if you cant have the best of both worlds like Elberoth.
There really is no big controversy here, if you have gret equipment in either format, you will enjoy the music. I still prefer the DSD tradeoff, even as I realize its still a tradeoff in dynamics vs naturalness against high grade PCM and PeterSt of Phasure explained (in an email) the technical reason better than anything I have read anywhere.
Charles Hansen of Ayre prefers PCM too, but less for tech reasons and more that he thinks its stupid to be having MORE formats when the mrket is already weak. He says PCM have started to make filter breakthroughs (learned from DSD playback design work) that make the differences so small that its not worth it for the industry to keep splintering. He thinks we should consolidate around PCM as a standard as it makes the most economic sense.
Miska (jussi) from CA forum thinks that you can keep PCM but now use cheap computing power to do the convolution and use the superior DS modulation algorithms to play back through a "filter box" Dac like his open source DSD1 Dac design (all SS). He even claims to do DRC work in pure DSD domain.
Given all these factors, i find the constant "revelations" by Siau as tiresome, repetitive and unhelpful. I dont see DSD proponents making all these persistent, desparate claims, as DSD seems to be advancing on its own merit. I dont see DSD people saying PCM cant sound good and giving spurious reasons why.
Let me throw my pal Flexi a bone. Converting DSD to PCM via Jriver and playing back on any PCM Dac, ie Trinity/Berk Ref/MSB, you name it, will NOT sound better than the same pure DSD track played by by a DSD Dac that does it "right". It just will not.
Adam is on record as saying the reverse is true as well. He prefers native PCM played back on Trinty, vs Jiver upconverted to DSD128 and played back thru his Big7 DSD only Dac. Bonzo preferred it when he heard it at his house, but Adam assumerd him that the Trinity ws not being fed by a proper transport at that time.
My only experience with Trinity was for a weekend in Holland and it was fed by the dedicated Trinity Transport and Trident Emperor grounding Box to Kondo amps to Genesis 1.1 speakers and it was lovely, but then agian the whole system was lovely!
