NorthStar
1. Use a Radio Shack level meter (analog's best).
2. Use the Radio 'shark' level meter compensation chart. * If you don't know about it, just ask me.
3. I don't know if it is your actual adjustments, but the Volume (Gain) seems to be set too high.
{Usually it should be between 9 and 11 o'clock.}
4. With a test audio disc (Avia Ovation), and with proper integration between your mains and sub, at the right crossover (best) point, I believe that your Low Pass filter control could be slightly higher, but every sub's numbers on the low pass control don't track exactly what it says. ...So it's tough to determine from just looking (test measurements are a must, then your ears).
5. Phase; you seem to know where's best. ...The Rat Shack is your best friend.
6. Use both the Left & Right RCA jacks (with a 'Y' connector) from the Line In. ...You'll gain 3-4dB gain by doing that, and eliminate any potential noise contamination.
