annapolis Raider
- Dec 14, 2013
Listening to the 0/96's right now.
Have Miles on the table, wait something's missing.
OMG, the trumpet, it's gone.....
ROFL....
I think I get what some are saying with the perception of something missing - as I have owned AN J speakers for a decade and now the AN E which is a similar design approach to the Devore (I've only heard the Orangutan once) so this is more about the AN E which I bought in August. I was out at a shop listening to very pricey slim narrow baffle design loudspeakers with several drivers and a Diamond tweeter with top of th eline Pass Labs gear. Listening to the overplayed "Keith Don't Go" by Nils Lofgren - the sound "seemed" to present all the information. Treble energy tends to give that impression but there was plenty of sparkle. But the overall impression was that of being tiresome. When I got home to my much less pricey rig (but with SET) the leading edge wasn't nearly as pronounced as it was with the $100k+ set-up - but it was far more enjoyable because the dots were connected together. One could very much say that the $100k system was more accurate in the sense that yo could hear more treble energy and I suppose air (although usually when I hear air it bothers me because in no live setting EVER - do I say wow check out the air around instruments. Air IMO is often mistaken for what it really is - grain. I have yet to hear ANY slim line designed speaker using multiple stacked drivers and highly varied driver materials that I would take over the likes of the new AN E/Alnico HE or Trenner and Freidl RA or albeit brief audition of the DeVore for regular domestic living spaces. In large rooms I'd go large horns or possibly a large electrostat but probably horns due to SET amps in my opinion sounding quite a lot better than SS (HNF variety).
The advantage the AN E appears to have over the Orangutan from what I can tell is that the AN E has superior driver integration - it sounds about as close to a single driver as it gets in a two way IME. The Orangutan uses a 10 inch driver versus the 8. The Orangutan has the advantage of not needing the corners or near wall position to gain low frequency response AND it is considerably more efficient allowing the owner to use 2 watt amps while the AN E will need 5-7 watts. But the AN E can also be had for half the price and can be upgraded in stages later. And those upgrades can be large. The AN E/Alnico HE is rather deserved the product of the year it got in 2013 from the Asian press IMO. But the AN E is better with concrete walls not the typical western home with plaster board which just sings along with the speakers which can certainly dull the upper bass and or create boom. They sounded their worst at CAS 2012 but was arguably a top 3-5 room at The Show in the Flamingo with concrete walls.
The main thing is that you don't buy systems that force you to listen to what the system can do well. If I had that Pass Labs expensive slim tower system - well I would not want to listen to music like Keith Don't Go. Instead I would be forced to buy whatever it does well and only those recordings. Most systems will perform reasonably well with good recordings - they're good after all. How does it do with music you actually like?
Yes the 3XL and Gibbon 88 are complete different animal vs O96. I'm really enjoying my O/96 on variety amps including Shindo . McIntosh and cheap 50 watts SS amp as well . I truly think for the price tag of O/96 I have no complain. Its a musical speakers. If you want to hear more details go find the silver back or other audiophile speakers. Let the O/96 sings with music I can sit down and listen to them all day.![]()
No Jerome. I can't even compare these two. If thats what you are asking.Paul,
If I understand correctly, you still feel the need to switch between the Westminsters and the O96 ?
Envoyé de mon iPhone à l'aide de Tapatalk
The O/96 is in my bedroom.![]()
Jerome. I absolutely love the O/96 though and they are beautiful to look at too.Oh I get it now !
This is a Devore thread. If you want to preach the virtues of Audio Note, should there be any, start an Audio Note thread.
IMO, the AN E at entry level is not bad but the whole Silver upgrade marketing deal is snake oil at best. The upgrades are large in dollars, not sound quality.
You are correct that unlike the AN E's the Devores do not rely on corner placement as was stated previously in another post.
There has been so much misinformation recently in this thread it is getting hard to keep track of.
thank you Richard i agree with alot of what you wrote here. ive never heard AN speakers but find myself in the situation that i run 12.5w and now its a 15w rating for using xls 300b tubes but have limited choice of speakers, the 096 is one of them, zu is also still on my list as well as well as volti, vapor, and a few others. im going to hear the 096 next week and i hope for the best. in an earlier post in this thread i mentioned it seems the 096 is love or hate among people i know. im not going to spend a fortune on speakers and i love my amp and the only way its going anywhere is if i change to the 25w allnic a5000's which would open up my choices alot more. alot of people love the look of the the 096 ,but i never really have. but to me looks are secondary to getting the sound i want and run the amps i want, the 096 is right in my budget and i hope to love it. unfortunately alot of the speakers on my list are internet ddirect and i cant really listen to them. the internet and threads like this one are very helpful to me, and speaking of a wide range of speakers in them is a great help. thanks again.I think there are general camps of loudspeakers of which the DeVore and AN E are cut from a very similar cloth with a similar target audience which is Single Ended Triode owners. There are not a lot of high end speakers on the market that are suitable to such amps (in the non horn and non single driver types).
As for the cables well AN usually changes the crossovers and the actual drivers so the difference in sound isn't as attributable to just the cable. The AN E/AlniCo Spx HE is only available in HK so far and is a rather staggering improvement over other AN E models. I auditioned this version with the Shindo Petrus preamp into Audio Note Kegon's at the owner's home who is a retired pianist for the Chinese Orchestra who previously owned far more ridiculously expensive speakers from Wilson Audio and the like. The Chinese drum direct to disc masters was astounding - even I as someone with a lot of AN exposure have not heard them do that before.
This thread has suggested other speakers and my view of these things is to audition similar products. A note for example was made about the the fact that the Orangutan was 1/3 more expensive than something else he was considering. Well the AN E/Lexus is $5,000 less than the O/96 and is quite easy to drive. 7 watts is enough. But it does have the upgrade option. There are pros and cons to these models but there are people who prefer the E to the DeVore and an E did just win product of the year and it has a longer track record. So when these SET friendly speaker ideas come up it's not a terrible idea to include several options as well as the likes of the Teresonic Ingenium or ZU Audio line.
I like the DeVore a lot based on my one audition and probably would be just as happy with them. Still I would want to cover as much of the Higher efficiency field as possible to audition.
I was simply responding to Steve (Petro85's question) regarding other opinions of the O/96's.
As far as missing info, you need to listen to recordings you know well. Of course, listening to Shelby Lynn sing Just A Little Lovin' isn't going to give the O/96's troubles. But give them big band, large symphonic or even moderately complex music and I FEEL they leave out a lot of details, not even micro dynamics, but a large part of the music. I'm listening to big band and saying, "but wait, there should be X, Y and X here playing now" and it either sounds very faint or can't be picked up at all.
This has nothing to do with audiophile sound vs musical speakers. Look, if the point is to just hear some sounds that are pleasing, fine. But if you want to get as close to live or as close to the recording, it's not.
You will get no disagreement from me regarding long time listening. From a fatigue standpoint, I could listen to the O/96's all day long. But when I listen, I want to be transformed to the event. And yes, there are speakers for $12,000 or less than can get you a lot closer IMO.
Neither way of listening is right or wrong - but that's just me. For me, when I listen to the O/96's, I don't feel like I've been transformed to the event - live or otherwise. I feel like I've been transformed to Walt Disney World's It's A Small World.
Kev - when I was listening to tracks I knew, I was listening for specific notes, specific nuances, specific instruments that augment the piece and they were absent. I can't explain it. I'm just reporting what I heard (or didn't hear). In some cases, yes, the trombone was barely noticeable, in other cases, the pluck of the bass was absent.
Look, as I understand it, building speakers is all about making certain trade offs. As I understand it, a designer has to chose between two of the three (but never all three): 1. super efficiency/benign load, 2. small size/footprint and 3. dynamics. It's rare to find a speaker that has all three, although some speakers like the Spatial Hologram M1's are giving this age old engineering limitation a run for its money.
If I wanted a super efficient speaker (although the O/96's efficiency ratings appear to be quite overly inflated - 91db measured instead of the 96db rated (Source: DeVore Fidelity Orangutan O/96 loudspeaker Measurements | Stereophile.com), a small footprint that is drop-dead gorgeous, yes, I would be willing to give up all the resolution, detail and dynamics of a lesser efficient or monolithic sized speaker and the O/96 would be in consideration.
But for me, I'm just not willing to give up the "I am there" or "they are here" objective.
YMMV
