I bought a month ago an Audioquest Cobalt too. The reason I took this is the same as yours: MQA. And what it does is reducing time smearing. After listening, I was quite pleased and the sound was much better then on my yamaha network player, even not with MQA. The latter I sold second hand for a big loss of money. But it is worth it, the Cobalt is a great DAC.
I was struggling with this, how to use this device? On what device is best to stream? Found a few solutions
- I have it on my Iphone connected via an Apple USB lightning to cam adapter, disadvantage, the power supply of batteries by phones tablets and laptops is not great
- use a pc and need to connect it to a USB 2 output. Disadvantage of that, the USB cable may not be too long and if you put the pc too close it disturbes the hifi set itself
- this is a very great streamer to put this DAC on, the SOTM-200 ultra neo a great choice for this
- this is a solution that is almost as good as previous, with a very great sound for 1/6 th of the price of the SOTM
, the Allo USBridge network bridge. It is a bang for buck solution, however you need a bit more work to install the right software in a linux based menu
I am not certain which one to choose, but it will be either the Allo, or the SOTM-200 ultra (neo)
