Constellation Inspiration 1.0 amp and preamp review
Hey Mike,
In the constellation inspiration 1.0 range there is also an integrated amplifier.
Just wondered if you had heard it and if so what your thoughts were on it?
Yes. It’s excellent. Same house sound. Not a 300 watt monster, but plenty of power and finesse and the same tube like Constellation sound. Liquid and engaging. Doesn’t get hot. Made in USA.
Thanks very much for sharing that Mike.
A review in The Absolute Sounds noted "While the 1.0 conveyed a general tonal signature that was dead-on neutral, its personality was ever-so-slightly shaded to the cooler side of the spectrum". Do you agree with that? I'd actually prefer something with a hint of warmth.
Constellation is under consideration to drive my speakers and I prefer a single chassis integrated. Its competitively priced too.
I personally don’t. I’ve always thought the Constellation sound is liquid and smooth. I say “sounds like tubes without the heat and fuss.”
Dead neutral SS amp? I would have to think on that. Bryston I guess.
Sterile and dry is CH and Spectral (just my two cents).
Liquid is Constellation and T+A.
Sweet is Luxman.
Big, ballsy and dynamic is Gryphon.
Warm is Pass XA.
Feedback is adjustable on CH. Is it possible feedback was too high so sound is sterile and dry?
I agree on Spectral. Sounds like my childhood family Pioneer receiver to MY ear.
Mike, in your view, where does the SIT-3 sit among these descriptions? Or a VAC amp?
Sweet is Luxman.
Warm is Pass XA.
The SIT-3 doesn’t sound like any other amp. If frankly doesn’t sound like an amp at all that you can compare it to. It does take a good hour to warm up, needs a high gain preamp and doesn’t like a high impedance or difficult load. It likes to float between 4 and 8 ohms, no less, no more. My 18 ohm speakers require me to put a resistor on it.
The Constellation is very liquid, smooth, slightly warm without any loss of detail.
The VAC is a tube amp through and through. Organic, rich, natural and musical and currently, my amp of choice for home.
Mike,
Thanks for the description. If you do not use a resistor, which are some speakers (in your experience) that you recommend that can be driven well by the SIT-3 amp?
Anshul
Some have tried it with the Harbeth P3ESR’s, I haven’t yet. I’ve only tried it on all my Avantgarde’s.
