I favor the vintage JBL sound, specifically the models using horn-loaded compression drivers. One of my prized possessions is a pristine pair of JBL L300 Summit (circa 1980). I play them in a medium-sized room decked out with Acoustic Sciences Corporation (ASC) treatments. The sound is punchy, thrilling, and vivid.
I have a separate, larger (28x17x9) room that I also use for audio. Currently, I use Audio Physic Cardeas in that room. They sound beautiful and can pressurize the room, but after loads of experimenting with placement and electronics, I’ve determined that they lack the impact and punch that I crave.
My sense is that the room needs speakers with big-ass woofers of a relatively high sensitivity to excite the air (i.e., to deliver the kind of punch that you feel in your ankles and belly). For clarity, while performance in the sub-bass region is important to me, I prioritize performance in the upper bass and lower midrange regions (60-250 Hz).
I’m consuming info about several speakers that may fit the bill. I plan on traveling, if necessary, to hear them. The Tobian 15FH is one of them. I’ve had a few phone conversations with Mike at Suncoast Audio, which is the U.S. distributor (and seller) of Tobian products. Mike has been very helpful, including by directing my focus among the Tobian speaker models considering my affection for the vintage JBL sound.
Speakers I’m considering:
- Tobian 15FH
- O Audio Verdande
- JBL K2 S9900 (used)
- JBL Summit Makalu
- Volti Audio Rival
- Vandersteen KENTO Carbon (outlier but I’ve owned and loved Vandersteen)
I acknowledge that the price range is wide. All the speakers are highly competent, I suspect. I’m wiling to spend for exhilaration.
So, forum members, lay it on me. Do you think I’m on the right track toward vintage-JBL-ish sound in a relatively large room? I’m highly attracted to the Tobian design and aesthetic , so it would be great to receive feedback from Tobian speaker owners.
- Tobian 15FH
- O Audio Verdande
- JBL Summit Makalu
- Volti Audio Rival
