Clarisys with subwoofers
ozzy
USA Michigan
I have 4 JL Audio F-113 Fathoms in the corners of my room and I discovered that placing the 2 that are behind the Clarisys speakers (front wall) to a phase setting of 180 degrees greatly improves the bass performance and soundstage for that matter.
The other 2 subs that are behind me and in the corners are set at normal phase. 0 Degree.
I'm thinking the improvement is because the Clarisys do project sound behind them, and that sound may be out of phase with the front of the speakers
ozzy
ozzy
Also don't forget even with only front radiating speakers different frequencies arrive both in and out of phase and everywhere in-between to the listening position.
ozzy
You discovered the power of swarm subwoofers. In my opinion, swarm subwoofers are very useful to smooth out the bass response. Every speaker type benefits from them. What crossover frequency do you set on JL?
Thanks. I have the crossovers set at 40hz. and at a low-level volume.
I still wonder about the speakers radiating sound behind them as well as in front if that is what makes the 180-degree phase setting work so well.
ozzy
So after back and forth many times, I am now of the mindset that though the bass is much more prominent with the front subs with the 180-degree setting, I think the bass is more bloated, the 0 setting though less, is truer.
ozzy
