CJ ET6 SE and ET7 questions
Mechnutt
Minnesota
Has anyone heard the ET6se and ET7 preamps? I am thinking about selling my BAT VK51se and buying a new preamp. There are no CJ dealers here in the Twin Cities. I was wondering how they sound and how they compare.
Also, I don't know if it would be a good match for my Pass X250 amp. I would be going from a fully balanced system to single ended. And CJ does not publish their specs such as output impedance. I will have to call CJ to find out.
Other preamps that I am considering are the Atma-Sphere MP3 and a custom Don Sachs tube preamp with all the upgrades.
I tend to like a slightly warmer, darker sound with excellent dynamics, huge sound stage with great air and transparency. It must have good bass slam. Too polite and my Magnepans sound lousy.
Thanks,
Larry
ET6/ET6SE Preamplifiers
Specifications
  • Gain:
    25 db
  • Maximum output:
    20 Vrms
  • Output impedance:
    100 ohms
  • Distortion:
    less than .15% THD at 1.0 Vrms output
  • Frequency response:
    at unity gain
    2 Hz to more than 100Khz
  • Hum and noise:
    98 db below 2.5 v
  • Tube complement:
    1 x 6922
ET7-S2 Preamplifier
Specifications
  • Gain:
    25 db
  • Maximum output:
    20 vrms
  • Output impedance:
    100 ohms
  • Distortion:
  • Hum and noise:
    100 db below 2.5 v
  • phase:
    inverts phase of all inputs at main out
  • Tube complement:
    1 x 6922
Dimensions
15.375D x 19W x 4.375H inches
Total Weight
19 lbs.
I've used the original GAT with XA60.5, XA60.8 amps as well as a few others. CJ mates perfectly with Pass.
Larry
Have you looked at the Backert Labs preamps. The crew there has been involved in working on CJ gear for years. They have "balanced" outputs and can work with you on appropriate gain much like Don.
Does CJ do audio shows? I am planning on going to RMAF this year. I have always been curious about CJ gear and based on reviews of their gear, I think that I would like it. I am curious as to how the new ET6se sounds vs the ET7.
I also like the sound of Luxman but I have not heard their newer preamps and amps. There are also no dealers in town.
Jack, thanks for the tip on Backert Labs. I am somewhat familiar with the brand but haven't heard their gear.
Here in the Twin Cities, I am pretty much stuck with ARC, Atma-Sphere, Mac, Electrocompaniet and Bel Canto. ARC, Atma-Sphere and Bel Canto are made here in town as is Magnepan, Van Alstine, Anti-cables and Exogal gear.
Conrad-Johnson replies...
"We may be attending the RMAF with my dealer AUDIOARTS , NYC , representing ZELLATON speakers".
Mechnutt, I have a PM for you from C-J... I'll send it along as soon as I figure out how.
Bob
It looks like CJ pushes Audioarts very hard. They always recommend them above all others. Hmmmm.
Bob
Gideon is one of their best dealers and cj just purchased a pair of the Zellaton speakers that Gideon distributes in the US. Nothing nefarious.
Thank you Myles.
I'd love to get your thoughts on the new ART 27A amp. Looks like it could be a great piece.
