hello all, any others out there listening to a circlotron? I built my own with 2 new mods. The first one deals with how the output the stages are coupled to the drivers, and a new bias circuit that needs only one supply per channel with a self-correcting bias stabilizer feature. I use no global feedback. The amp is based on a grommes 260A front end/phase inverter with an additional 12BH7 to drive the 3X3 6550s per side. Using so many 6550s allowed me to series string all the tubes (except the 12AU7 preamps) of which I have a separate DC supply, and now have no filament transformer except the small one for the 2- 12AU7s. I cut the 120VAC in half with a half-wave diode, and get almost the perfect supply. I still have a little diode switching noise, but am going to try some nte 577 diodes, which have a 70 ns switching time, so I'm hopeful that will kill that noise, but it's nearly inaudible as is. Hope to get it as quiet as my Mac 275 I used to use before this this was done. I've been trying to get my new 'puter to upload pics and schematics, so far my new chromebook hasn't been successful in this. Will bring in my 'puter guy if there is any interest in seeing any of that. The output impedance is a little over 200 ohms, so I'm using 3 sets of bose 901s with the 8 ohm speakers wired in series in each system, then all speaker cabinets wired in series giving about 192 ohms per side, which I have turned around and am using the backs as front sides, and having removed the ninth, normally front speaker. Sounds great for an oddball high impedance experiment. In fact, sounds better than my Mac. Still can't believe what a difference not having output transformers makes in imaging. And having no crossover components as I'm using the full range boses, the bass detail is remarkable. Stacking up the boses on top of one another really makes them sound totally different than I would have imagined, those 24 speakers per side really add up to a lot of surface area. Thanks, midmoe
