psjl
Audio Snoopster
- Jul 6, 2013
Welcome to the forum Philip!
Thank you for joining.
Thanks Joe! :hey:
Hadn't seen you around AA.org for quite a while, but really glad to see you over here in AudioShark.org!
Welcome Philip!
Brett,
Looking forward to your S5 amp. One of my dealers is eager to get his for demo.
Great info on Bret's creations. It all sounds very exciting and I can't wait to get my dealers report. I love the tiered bias scheme. It is often I listen to music in the background and having the ability to tailor power consumption to listening mode seems extremely smart.
This is my new home now, lots of great members here.
Joe,
I have been lurking around this forum for quite sometime now, and have to agree that this is indeed a great forum with great members!
Glad to see that you are a Super Moderator in this forum.
Thanks for having me in this forum!
Has anyone heard the new Krell Solo 375/575 amps?
I have also been closely following Bret D'Agostino's development of his 5 Series amps/preamp for quite sometime now, and it really is quite exciting stuff!
After CES 2014 in January, I visited BSC Audio in Milford, Connecticut. Bret was very kind to invite me to listen to his 5 Series M5 class A monoblock amps in his personal home setup. The amps were driving a pair of Wilson Audio Sasha W/P speakers (Series-1) and hooked up directly to a Bricasti M1 DAC with Transparent Audio Reference MM2 cabling throughout. Without going into a whole bunch of descriptives, I can say that I was pretty stunned with the sonic performance, and this is coming from an owner of his Dad's Momentum monoblock amps. The rest of my system consists of Wilson Audio Sasha W/P speakers (Series-1), Ayre KX-R preamp, Playback Designs MPS-5 player, and Transparent Audio Reference cabling throughout.
I also had listened extensively to his Classic Series BSC-100m class A monoblock amps when they first came out and was extremely impressed with their sonic performance. They were really fast/dynamic amps which is exceptional for class A amps. Expansive 3D soundstage, highly musical yet transparent, and in particular, very full-bodied/soulful. At USD 14,750 per pair it was a (relative) steal. Had I not already bought his Dad's Momentum monoblock amps, I would have given Bret's gear serious consideration and saved a bundle of cash as well.
But his 5 Series monoblock amps are something else altogether.......They were like his Classic Series BSC-100m class A monoblock amps on steroids, and then some! I do love my D.D. Momentum monoblock amps, but Bret's amps were sonically so very tube like, and yet had tremendous speed, super rich timbre/tone, great layering of instrumentation, ultra-wide soundstaging, as well as having the good ol' Krell "slam" in spades, the difference being that it was very well proportioned top-to-bottom with great musicality. In addition, there was also a startling sense of palpability and realism to percussive instruments. The "twang" of the guitar intro. on Gotye's "Somebody That I Used To Know" gave me serious goose bumps and has stuck in my audio memory to this day. I hate to say this, but when I listen to this same track on my D.D. Momentum monoblock amps back home, I unfortunately don't get the same type of goose bumps.
Bret's new 5 Series amp design aesthetics are inspired by performance cars, as can be seen by his 2-tier top panel with the grills dominating the top panel. In fact, Bret has actually enlarged the grills in order to add more of the muscle performance car look & feel, as well as increasing the more rapid & efficient flow of heat up and away from the amp chassis - and it does look a lot more "meaner" (in a very good way). In addition, the front panel is sculpted to reflect the strong curves and elevation changes much like a performance car, and the 2 bulges on the front panel flanking his center column (housing the power button & bias control) convey a sense of serious power from within, very much like the bulge that one sees protruding up from the bonnet of a muscle car.
Bret's 5 Series M5 monoblocks and S5 stereo amps are full class A amps which will double all the way down to 1 ohm (with room to spare), and I believe they are rated around 150 watts & 75 watts respectively. Class A bias can be reduced from 100% down to 50% or down to almost 0% which is in effect a low power Eco mode via the triangular knob on the front panel. Also, the S/N ratio is around 110dB (unweighted) which is equal to or better than his Dad's Momentum monoblocks amps, thus making for a very low noise floor. I also really like the fact that his heat-sinks are all internal, and that his output devices are nestled right in-between his massive heat-sinks thereby creating a "chimney effect" for the heat to shoot straight up instead of radiating heat laterally when the heat-sinks are bolted externally to the sides of an amp which will likely heat up a listening room considerably.
I was about to pull the trigger on his Dad's Momentum preamp, but have now decided to wait to audition Bret's L5 preamp with 3-Band Tone Controls WHICH can be controlled remotely (whereas his father's tone controls cannot be controlled remotely), plus I believe that Bret's preamp will be about HALF the price of his father's Momentum preamp (USD 32,000). If Bret's preamp matches up nicely with his Dad's Momentum monoblock amps (which I currently have), then I'ed just have saved a ton of cash!!
Adaptive bias is not really Class A as there is a frequent transition state for the devices
A little bird told me there was a thread about Class A, which of course is so near and dear to my heart. How are the folks on the Shark today? My 2 cents is that: 1. This would have to be focused on solid state amps as correct me if I am wrong but most tube amps are closer to Class A by design than not? I have very little experience with tube circuits so forgive my ignorance. 2. Adaptive bias is not really Class A as there is a frequent transition state for the devices, and in my experience this negatively affects the sound. To that end the products that use/used adaptive bias may actually sound better if that circuit were eliminated. Even dear old dads monsters from the past using adaptive bias would have been better without it. He and I have discussed this many times... But from a marketing standpoint it sounds much better to have Class A in the description and save a huge amount of space using smaller heat sinks. So that being said, we can eliminate many from the list and add BSC because even though my company is only 4 years old I have had only Class A amps from the start and don't plan on going anywhere for the next 15-20 years or so.I still contend the biggest and baddest of all the Class A amps is the KRELL KRS-200. I don't think anyone has come close to surpassing this Fixed Class A monster. I do have plans for a 7 series amp that in concept will better the KRS-200, but it is time, budget, and market dependent. I also agree Nelson Pass designs to be #1 as he was one of the first and continues to deliver fine Class A products, but Krell shouldn't be #9 as the first 15 years of its existence were based on Class A designs. Definitely Gryphon and Accuphase are greats on this list, the 1st Levinson 25 watt class A ML2 should be an honorable mention, good amp!. Also some Class A efforts from Bedini and Belles which I believe had good sounding Class A SS amps.
Hey Myles,Hi Brett!
Welcome! How'd the move go?
Hey Myles,
Staying in CT for a while, son is going to school here and no need to jump ship just yet... Need to visit each other soon!
This was after his earliest effort. You heard his latest version. His amps are more based in the earlier KSA 250 than the later Krell products.
I'm glad Bret mentioned this. I agree sliding bias is not Class A. A good example is the new CEC amps. They claim Class A, but doesn't come close.
