Bughead, cables and DAC's
Mechnutt
Minnesota
Last night I had 2 friends over to compare DAC's ( PS Audio with the Yale software to my Luxman DA-06) and 3 usb cables ( Light Speed, WW Starlight 7 and the WW Platinum) with and without a Regen Amber. I also installed Bug Head and we compared it to HQ player.
Here are my impressions-
DAC's-
The PS Audio was the clear winner. It had a blacker background, more air and transparency. There was a bit more detail and resolution. The sound stage was slightly wider and taller and bass was tighter and hit a little harder. The thing that impressed me was the space between instruments and the way that percussion hit hard. Cymbals also sounded more natural and smoother. The Luxman however does have a thicker midrange and some low end bloom that gives it a more lush, musical sound. The only issue's for me is that we could not get native DSD music to play with the PSA with HQ player. The other issue is that the guy that owns it states that the PSA sounds better when using the network rather than USB. However, I am now considering selling the Luxman and buying the PSA. The Luxman did not get embarrassed but the the PSA was better in most instances.
Cables-
I have been using a WW Starlight Platinum USB cable. We compared it to the Light Speed and a WW Starlight 7. The differences were not subtle. The clear winner was the WW Platinum. In my system the LS was way too bright and difficult to listen too. It has good detail but high frequencies were screechy.
The SL 7 cable came in second. It had the darkest and warmest sound. High frequencies were rolled off. It has the least transparency and detail of the 3 cables. It was very forgiving of bright recorded music. It was pretty disappointing to hear how this cable paled in comparison to the detail of the other 2 cables, especially since it is a highly touted budget cable.
The WW Platinum was the clear winner. It was neutral sounding with just a hint of warmth. Treble and high frequencies were smooth and detailed. It had a wider sound stage with more transparency and it was the most musical.
After we compared all 3 cables we inserted the Regen. Adding the Regen made all 3 cables sound about the same. I would like to know how it can take brightness out of a cable and add detail. It clearly was the big equalizer for the cables.
My friend who owns the WW Platinum and the Light Speed says the LS sounds better in his system than the WW Platinum and I have heard his system and it sounds great. It indicates to me that USB cables can be system dependent.
Bug Head-
We compared my newly installed Bug Head player to my gold standard HQ Player and the results were eye opening and jaw dropping. One of my friends has been touting Bug Head for a while. He has been raving about it. So we installed it and I got a quick tutorial on how to configure it and use it. There definitely is a learning curve with it and it has its draw backs. First off, you need a minimum of 8 gigs of ram and and a good I5 or an I7 processor. You need 16 gigs of ram or more if you want to do native DSD (my laptop is a new generation dual core I7 that runs at 2.4 and turbos to 3gHz and it has 8gigs of ram and we got some cut outs with native DSD). It also can take a minute or more to load albums depending upon the settings that you use. Another draw back is that you can't make a play list and have songs at different resolutions. You have to pick one resolution and stick with it. Overall the program can be a frustrating. It is good program it you want to listen to whole albums. It you want to skip around or listen for 20 to 30 minutes then look else where. Music takes so long to process because BH wipes you RAM clean reconfigure's and reloads it.
Now for the sound. Bug Head was the clear winner by a wide margin. It makes 44k sound like great DSD recordings. BH is much more dynamic and musical than HQP. It has a darker background, more air and transparency. Textures are just beautiful on vocals and horns. Piano was real and palpable. In fact, it made instruments sound real and in the room with you. Cymbals were smooth, detailed and had good air. Bass is deeper, punchier and tighter. I felt more connected to the music and was hearing things more clearly. BH made my Luxman DAC sound more like the PS Audio DSD. Another plus for BH is that the Remote user interface Splash Top works great with a tablet to control BH. It does not work well with HQP due to screen size.
Unfortunately we did not have time to hear BH with the Regen. I should get mine in the next week or two. I will report back then.
Bug Head will be my go to player when I want to listen for an hour or more otherwise it will be HQP. By the way, my 24 year old son heard BH an today he can't stop listening to my system.
Larry
Larry, vis-à-vis Bug Head:
My music computer doesn't have balls to run Bug Head in real-time; does the program have the ability to save to file? Specifically PCM 24/88.2 or better in WAV or FLAC?
BTW, I tried downloading Ver.5.24 but my Avast! antivirus thought the Zip file had dangerous program and blocked it.
Bill, BH takes the music from your music files that you have stored on your computer and imports what ever Album, song or play list that you have. That is why it takes anywhere from 15 seconds to 130 seconds to load depending upon what settings you use in BH.
BH is not a signed program so windows or your Antivirus may alert you that it is a virus. Just ignore that, turn off the Avast and install BH. The latest version of BH is 5.31. It truly is a huge step above JR and HQP. I rarely use JR any more because HQP sounds way better and BH is even better than HQP.
One more thing Bill. BHead will import your music file in what ever Rez it is in.
Bill the latest Bug Head is called Infinity Blade version 5.31
You can download it here at the bottom of the page
(I hope this isn't a double post.)
I downloaded and unzippedd Bug Head 5.31 but I'll have to hold off trying it at least for a while. My music computer doesn't have the sinew to run it and my main desktop doesn't have a compatible DAC.
I might have a look at HQ Player.
Bill,
HQ player is much better than JR. It has a learning curve and the user interface is not as good as JR. You need at minimum a very fast I3 processor (I have 2 laptops and one has an I3 running at 2.5gHz and it was able to do 1x DSD with the antivirus turned off) and 4gigs ram for HQ player. Really you should have a fast I5 or better as the program will run smoother.
Winson,
BH will is for computers and servers as far as I l know. I listened for 3 hours yesterday and I still can't believe the difference. The texture, musicality, dynamics and space between instruments is amazing. The current version 5.31 is supposed to sound the best from what I have read. It has just barely a hint of warmth and darkness compared to prior versions which I have read had a hint of brightness. Last night I tried upsampling and it works great and sounded great. It can do 88, 176, and 352kHz. I preferred 88.
Thanks for the tip on the PS Audio DAC. I am going to hold off for now since BH makes my Luxman sound very similar to it but more musical and dynamic. I have a Regen and Jitterbug coming ( I was using a friends Regen for 3 weeks while he was in Germany) and will see how things sound.
Is any one else using Bug Head? The latest version 5.31 is supposed to have a slightly warmer and darker sound. I love it.
Feedback I got:
So far it's the best player i heard! But usage is not easy .
Try it. It will AMAZE you! ����
and
I was using it happily on E3-1265 Xeon. It does need a bit of cpu pwer, but
not as intense as HQPlayer. Lots of RAM is also good, but will also work perfectly
fine with 2GB of RAM, so no need to worry. Yes, DSD is no problem as well.
Feedback I got:
and
Now way it will do DSD with 2 gigs of ram. I tried DSD with 8 and I got drop outs. Read the talk on the jplay.eu forums on BH.
Hello All,
I too have been using BH for some time.
I have been bouncing around but am not sure about the confusing settings.
What settings are you using?
Welcome to AS TES!
I am using version 5.31. Here are my settings.
On the set up page-
1. Correct Clear Sound is Red
2. Memory Envalid is Red
3. Set PCM1792A I have used it turned on=Red and off = blue. I am not sure if I can tell which sounds better
4. Set pink/gold. white is set to Blue
5. Auto Phase Adjust off
6. zTune set to Red
7. Is enabled
9. Shape Clear sound is set to blue
10. Rewrite Wallpaper Red. Sometimes I turn this off. The sound is suppose to be better with it on. I have do do more listening.
Select mode- I use normal or upsampling. 2x or 88kHz is the sweet spot and sounds better than DSD on JR and HQ Player. Other resolutions sound great and the higher settings have a bit more air and holographic sound
I enable stardust mode and usually use 2x stardust because 4x adds a little more time to load the music.
On the play page I use Blade 20 which the designer recommends for best sound and I agree so far. I am not sure if you know this, but if you left click just to the immediate right of LPF Free at the top of the screen, you will open up another menu where you can set the Star Dust to 2x, 3x or 4x. You can also turn on Shape Clear Sound.
Once you get the hang of it, it is not too complicated to use. The Sonic benefits way out weigh its clumsiness. The tonal richness, depth, textures, sound stage musicality and dynamics are on another level. Spacing between instruments if fantastic. My jaw dropped when I heard the difference. And it is a free program. I have not used HQP or JR since installing it.
I am running 2 sticks of 4gig memory and I am going to upgrade to 2x8gigs for 16. The sound is supposed to be better and I think that the program runs a little faster.
Play around with the settings and see if you can hear differences.
I did get DSD to play without dropouts.
