CPP
interesting feedback. i apologize for all the questions below, but there are so many rack issues of context that i'm wanting to fully understand.
Adona makes a number of racks. to my knowledge Adona does not have racks with isolation suspension points (maybe it's something new). it would be helpful to know which model you used? and with the Adona did you use spikes? and did those spikes get through your carpet into the concrete?
does your wood rack weigh more than the particular Adona rack you tried? and does your wood rack have flat feet, or spikes?
and can you provide a link to the 'Hebbies'? thanks. did you use the 'Hebbies' with your wood rack too? it appears that the VPI Classic 1 turntable uses integral decoupling footers. did you bypass those footers with the Hebbies? or place the VPI footers on top of the Hebbies?
the idea of a solid steel/aluminum rack (Adona) is to provide a solid base for footers you would use between the granite shelves and your gear. in essence the footers are then an impedance layer. solid wood will add lots of mass, but also will have it's own resonance too. do you use decoupling footers under your gear on your wood shelves?
Giant Fat Glider
– Herbie's Audio Lab
Adona Audio Racks I guess they call it independent support system. It was a nice rack and since it was close to my home a big savings on shipping.
I would say, my racks are about the same weight about 100-135 lbs
No spikes on the tile, but I did use Cone/Spike Puckies
Just place the equipment on the shelf, no footers were needed. The way I look at it, if the needle on my gauge didn't move, why waste the money on other footers under the equipment,. We are talking 2 " of thick maple for 3 shelves and under my TT,the top shelf (4th) its almost 3" of solid maple. Custom Furniture, Hi End Audio Stereo Racks and Isolation Platforms at Timber Nation.
Hope this helps
