Binary Acoustics 1900: More Than Just 1s and 0s
_theaudiofile
TL;DR
$235 hybrid. Light on the ears, punchy mid-bass, clean mids and soundstage depth above its price tag. Sub-bass rolls off early, but the instrument layering is great.
The Binary 1900 has been in my rotation for about three weeks now. Passive radiator in with four BAs and a dynamic driver felt like a gimmick, so I wasn't expecting much. But in practice, it works. It skips the usual trick of boosting the treble to fake detail, and it doesn't try to drown you in sub-bass rumble either. You just get a clean, engaging sound with tight mid-bass impact, smooth vocals and depth that keeps busy tracks feeling uncluttered.
Contents
The IEMs, a 2-pin silver-plated cable (3.5mm or 4.4mm), six pairs of silicone eartips (two bore styles), a zippered hard case, a cleaning tool, and the paperwork.
Build
Fit is great: lightweight resin body, steel faceplate and an easy seal with zero ear pressure or driver flex thanks to the vent. The laser-engraved 316L stainless steel faceplate is a homage to the film The Legend of 1900.
Stock tips are on the thick side, I swapped them for SpinFit. My main annoyance is the cable itself: it’s stiff out of the box, keeps kinks below the splitter, and lacks modular plugs. At $235, you really should be getting a modular cable in the box.
Power
You don't need a heavy-duty amp setup for these. They run easily off a basic dongle or headphone jack with tons of volume headroom to spare.
Isolation is solid too. Since the shells sit flush and seal well, they cut out background noise and typing clack without needing active noise cancellation.
Sound
Bass
Mid-bass is the highlight of the low end here. Kick drums and basslines have a tight, snappy punch that gives tracks plenty of energy without bleeding into the lower mids. On rock tracks like Dire Straits' "Money for Nothing", the drum opening hits with speed and tactile impact without lingering bloat. Sub-bass drops off pretty quickly under 50Hz, though. On heavy sub-bass tracks like Hans Zimmer's "Why So Serious?", you miss out on that deep, physical sub-30Hz rumble unless you add a bass shelf with EQ
Midrange
The mids are where this tuning really shines. You get a nice natural weight to vocals that keeps them sounding full but never congested. Male vocals have solid chest weight, while female vocals sit right where they should without getting shouty at higher volumes. Instrument timbre, especially piano and acoustic guitar on tracks like Fleetwood Mac's "Landslide", is spot on. Resolution is easily above average for the price, presenting detail smoothly rather than forcing artificial sharpness at you.
Highs
The high end strikes a nice balance. It gives you enough sparkle and detail to keep cymbals and percussion sounding crisp, but stops well short of being sharp or metallic. It's clean, non-fatiguing, and handles bright recordings without throwing harsh peaks at your ears.
Soundstage
The soundstage isn't insanely wide, but the instrument separation and depth are outstanding for $235. Everything feels spaced out logically in 3D rather than squashed into a single line. Even on complex, cluttered mixes like Yosi Horikawa's "Bubbles", you can easily isolate individual background instruments, bouncing textures, and vocal harmonies.
Tradeoffs
Main downsides? Sub-bass rolls off pretty early under 50Hz, the stock tips are too rigid, the cable is stiff and non-modular, and soundstage width is fairly average compared to its depth.
Verdict
If you're after a comfortable daily set with natural vocals, snappy mid-bass, and awesome 3D depth, the 1900 is well worth $235. Hardcore bassheads needing deep sub-bass vibration or cable purists who want swappable plugs should look elsewhere. But for clean, easygoing listening across most genres, it's a really solid set.
If you made it this far, thank you for reading and catch you on the next drop.
