Although I'm in the early stages of setup for the Berkeley, the PS Audio is on equal footing as far as DSD goes. When PS Audio did their update on the Direct Stream, the DSD playback got maybe another 10% better.......but the redbook playback went backwards maybe 15% IMHO. They softened up the top end a bit too much for my liking. If they could have kept redbook the same and only modified DSD playback, I think the Direct Stream would be nearly equal to the Berkeley. But that is considering my small amount of time to dial in the Berkeley. I usually try 50 or more combinations of IC's, digital cables, and power cords before settling on what sounds best to me. The Berkeley has @ 600 hours now, so it should be starting to find its voice.
I did leave the unit on for 18 hours straight yesterday, as some stated it would sound better fully warmed up. It sounded mostly the same to my ears, but I will keep it on for several days to fully test this suggestion.
As far as the Lumin/PS Audio comparison, I liked the PS Audio better because of much better bass performance. But I have to qualify this preference, as this comparison was done in Mike's upstairs listening room. And it has known bass issues that can create havoc. This comparison was done "pre-Strad". So the results might be totally different, now that he has the Sonus Fabers up there. Maybe the PS Audio was leaner in the bass, and helped out a room with bass issues ?? Although, the Direct Stream is providing outstanding bass in my new 28' X 24' room. So I doubt it is lean in the bass region. The Lumin did a bit better job fleshing out detail in the 2k to 5k frequency range. And with the new software update for the Direct Stream, this would be even worse because of the softening in the upper frequency region.
This is the best comparisons I can offer so far. Like I said, it is very early in the review process for me. I try to spend at least a couple of months with a new piece of gear, and try every combination I have at hand. I usually flesh out major improvements with every piece of gear, once I stumble upon the right combination. I definitely avoid snap decisions, as synergy is the key IMHO.
Early score......8k-10k good. Still searching for 16k of value. But I believe it's there. Now, back to audio wack-a-mole !!!
