Audio-Technica ATH-R50x Review: Pure Neutrality on a Budget
_theaudiofile
TL;DR
A $159 scaled-down R70x. Featherweight at 207g, dead neutral, and completely uncolored. Bass is lean, mids are front and center, and detail is solid for the money.
I've had the ATH-R50x plugged into my desk setup for about three weeks now. Audio-Technica isn't trying to sell a "fun" headphone here. There's no low-end bump or rolled-off treble to smooth things out, just a flat reference tuning built for mixing and editing. If you already like the clean, lean presentation of something like the HD560S, this sits in that exact same mold.
Contents
In the box, you get the headphones, both a 1.2m and 3.0m straight cable, a 6.3mm adapter, a soft carrying pouch and the usual documentation.
Build
At just 207g, you barely feel these on your head. Dropping the old R70x 3D Wing setup for a simple padded headband was a good call. The clamp is light, so there is zero top-head pressure even after hours at the desk.
The velour pads keep your ears cool, though the plastic build does feel pretty basic in hand. My biggest annoyance is the 2.5mm twist-lock jack on the left earcup. It keeps the stock cable locked in, but good luck finding a custom cable that actually fits into the recessed slot.
Power
At 50 ohms and 93.3 dB sensitivity, you do not need a beefy amp setup to run these. Plugs straight into a basic interface, a cheap dongle, or a laptop jack with plenty of volume to spare.
Because it is a full open-back, isolation is basically zero. Outside noise leaks right in, and anyone nearby will hear whatever you are playing. Keep these strictly for a quiet desk setup.
Sound
Bass is clean, quick, and tight. Mid-bass punch gives kick drums and basslines plenty of clarity for mixing, but sub-bass drops off pretty fast under 45Hz. If you want deep rumble for hip-hop or EDM, you will definitely need to throw some EQ at it.
The midrange is the best part of this tuning. Vocals and acoustic instruments sound natural and crisp, with zero lower-mid mud or harsh upper-mid shout. Highs are clear and detailed, carrying enough bite to highlight bad mixes or sibilance. The open design keeps the soundstage feeling natural, and instrument separation is sharp enough to easily catch panning moves or track footsteps in games.
Tradeoffs
The main downsides come down to that early sub-bass roll-off, the proprietary 2.5mm cable jack, zero noise isolation, and a basic plastic build.
Verdict
At $160, the ATH-R50x hits the mark if you need a featherweight, flat reference set. If you are after heavy bass or a warm, relaxed presentation, pass on these. But for mixing, audio editing, or clean, uncolored listening, they pull their weight.
If you made it this far, thank you for reading and catch you on the next drop.
