Randy Myers
So a bit of an update. I really like my LS17 SE. It seems to be built fantastic, sounds wonderful without a bunch of frills. One feature it has that I really find important is that the pre-amp has three outputs which is very important to me.
The reason that three outputs is so important is a bit of a change in direction. I love the T+A amp, even though it is so small...
, and as I said I was impressed with the Goldmund Job 225 amp... so a recent find thanks to another AS member.... the NuForce STA200.... this little amp is developed by Goldmund and distributed under the NuForce name... basically it is the Job 225 at a little less power.... The rear looks identical to the Job other then better connection being used on the NuForce.
The bottom line is the recent sale was so low that I could not resist.... getting a Goldmund amp at this price was simply incredible... and I have been able to use my Rothwell Attenuators to match the levels.... and using both amps in a bi-amp configuration... it seems to be a really great combination ...
Therefore three outputs are important because bi-amping uses two outputs and the third to go to the subwoofer. From what I can tell the current ARC pre-amps have only two outputs (assuming that on output 1 and 2 you can use either the XLR or RCA, but not both).
