Octopoulpe
Hi everyone
I have a project where I need to connect my laptop to 10 different guitar amps.
My idea is to buy an audio interface with 10+ outputs (I don't really care about inputs)
For example, I found those :
- Behringer UMC1820 (10x 6.3 mm jack line outputs (1 + 2 monitor output L/R))
- Tascam Series 208i (2 Balanced TRS main outputs with front level control + 6 Balanced TRS outputs + 2 Stereo headphone outputs)
- ESI U108 PRE (8 Balanced line outputs: 6.3 mm TRS + Stereo monitor outputs: 2x 6.3 mm jack + Headphone output: 6.3 mm jack)
My question is, with this kind of audio interface, can I send a different audio signal to each output channel at the same time? I guess(and hope) the answer is yes. But I really need to make sure about it before buying anything
Thanks in advance for your help!
