a.wayne
Balanced Audio Technology should do the trick! At least the big solid state amps...
4 Ohm only , weak amplifiers IMO.....
Pass amps are awesome, but I’ve talked to them and they are stable down to the rated wattage (4 ohms).
Never experience any issues at all over the years. In fact many Martin Logan owners own Pass Labs amps to accommodate their Speakers.
Here is their claim taken directly from their website:Sanders magtech amplifiers are way too small to have a "fully" regulated PSU ......
Not a nominal 1 ohm load, but some ML models present a 1 ohm load across a limited bandwidth in the high frequencies.I dont recall Martin logan making a 1 ohm load speaker ....
regards
Sanders has solved these problems by developing a voltage regulator that is essentially 100% efficient. There is no heat dissipated by the regulator system. There is no high-power/high-voltage switching that causes heat generation or RF problems.
The regulator in the Magtech amplifier maintains a stable voltage regardless of load or reasonable changes in the line voltage feeding the amplifier. It runs stone cold, produces zero RF energy, and is simple and reliable.
Unlike other amplifiers, the distortion in the Magtech amplifier is virtually unchanged regardless of power level. The bias is stable regardless of load.
Spectral are great sounding amps , but not for 1 ohm loads .....
...says someone who hasn't heard what I did with them driving MLs.
I haven't heard yours, but i have heard spectral and know the design well, it's not for 1 ohm , not enuff heat sink area , limited outputs so high beta droop.
What would interest me if you can, is an impedance graph on your modded ML's , i would consider a true 1 ohm load as being 1 ohm from 500 hz-20K, plenty musical content there .....
Regards ...
Regards ...
It's not mine, but those of a friend (ML Odyssey). The panels are not modded.
I've heard the set-up many times, it's not a fleeting one-time impression. If you want to arm-chair argue with me, be my guest, it won't do you no good.
What about at 71hz? [emoji6]
Mike a 1 ohm dip is too narrow to be considered 1 ohm load as it will be confined to just that frequency. any decently built amp will not have an issue plunging such depths , of course there are those who will shy away for the moment ...![]()
It’s multiple frequencies around 1ohm.
If with low sensitivity , then yes , big issues , no worries, you have an arsenal of amps quite capable ....
