AM Audio Amps
wizard
A-300X at €58500 /pr - they are actually cheap for the performance they offer.
300/600/1100 watt class A! in 8/4/2 ohms. It can also be used in class A/B with a switch on the back.
They also have A-1000X a 1000 watt class A/B version of A-300X - A-1000X deliver 100 watt Class A in 8/4/2 ohms.
A-300X has 2,75 Farad of caps.
A-300X weight is 136kg each.
Soon AM will release the smaller amps in the Excellence series; A-120X monos, A-60X stereo and PA-60X integrated amp.
PA-60X integrated amp - check out the thickness of the front, and the size of this amp - it will be one of the biggest integrated amps on the market when released.
Now some cheaper AM amps, but the sound of B-130 is phenomenal for the price at €12000 /pr.
AM products is built like jewelry inside, many brands could learn a lot of AM.
It's not only good enough with good looks outside, but also the inside must look good.
And AM is using only the best components - also many mil-specs components.
The unbalanced 82kg each A-200 S2 at €11500 /pr. The sound is exceptional like B-130.
A-200S2 is the most sold big AM amp in the history - it started in 1993 when AM released the 70kg A-200M.
WOW!!!!! Those are monsters and beautiful.
...And very heavy and very expensive too! :eek:
That's about $90,000 Cdn or so for a pair (cheap)! ...And 300 pounds, each!
* On the very first picture of the first post, I counted 20 power transistors per channel, but that's only from what we can see on top. ...And I bet that they are well hand-matched too. And that toroid, looks like a real monster, perhaps 8 kva (two stacked 4 kva's)?
...I wish I was born a Sultan from Arabia or somethin'. ;)
Still in my book, this is the one to beat.
Krell MRA mono blocks = 1,000 watts 8ohms - 2,000 watts 4ohms - 4,000 watts 2ohms - 8,000 watts 1ohm - 16,000 watts 0.5ohm - 683 pounds and $150,000.00 pair.
PS: If i didn't live in a condo on the third floor i would have a pair.:):):)
OK GUYS IT'S JUST A JOKE// I'M $149,000.00 SHORT
Krell MRA 01.jpg - - - Krell MRA 02.jpg - - - Krell MRA 03.jpg - - - Krell MRA 04.jpg - - - Krell MRA 05.jpg
Actually there are 40+40 power transistors pr channel, and the price is including 21% Italian VAT.
For sale outside EU the VAT is deducted.
Krell MRA mono blocks = 1,000 watts 8ohms - 2,000 watts 4ohms - 4,000 watts 2ohms - 8,000 watts 1ohm - 16,000 watts 0.5ohm - 683 pounds and $150,000.00 each.
OK GUYS IT'S JUST A JOKE// I'M $299,000.00 SHORT
View attachment 584 - - - View attachment 585 - - - View attachment 586 - - - View attachment 587 - - - View attachment 588
MRA price was $150,000 /pr.
And at normal operation it don't go down to 0,5 ohm - a special software key must be inserted to go down to 0,5 ohm - none of MRA sold use this key.
I see you've copied the MRA from my blog, and I've heard MRA - the best Krell amp ever.
Net weight is 275 kg each - I lifted them with a inside crane when I listened to it.
In short - one of the best amps ever.
Now we wait for D'Agostino to release his new heavy Momentum (or a different name) super amps.
Thank's for the info, post corrected, i have a few friends that own KRS-100s all with Acoustats.
Each MRA weights 600 lbs each.
You can buy slightly used pairs for around $70-75000 /pr.
You sure that's not an electrical transformer?? :p
PI Greco A-1000X made by AM Audio.
A-1000X has been conceived to establish a reference point in their category, providing high power and an outstanding music reproduction quality.
A-1000X is a balanced amplifier consisting of two symmetrical amplification
circuits. The input amplification stage of this power amplifier only uses two active components: the first MOSFET (2SK214) covers the whole voltage gain required, while the second one (2SJ77), features only a current gain, ensuring a low impedance output. As in all PIGRECO’s power amplifiers, the final stage provides a both current and voltage amplification.
This power amplifier employs 20 pairs of selected MOSFETs for each sub-amplifier, for a total of 80, which are able to deal with steady currents of 140 Amperes and to dissipate 8kW at 20 °C.
Electrical paths are as short as possible: two IR 36A/400V diode bridges, attached and dissipated to the frame, are connected to the 3000 VA transformer. The toroidal transformer has been manufactured with great care and resin-coated inside the large, 2 mm-thick, polished and chrome-plated black steel container, which is insulated, by means of 12 vibration dampers, from the 3 mm-thick steel frame. The frame is laser-cut and reinforced with 12x20 mm aluminum bars.
Filtration is obtained through various stages, using several parallel electrolytic capacitors providing 120,000, 8.200, 5.600, 2.200 and 47μF respectively, and polypropylene capacitors providing 100 μF, for a to tal of 1.2 Farads for each monophonic power amplifier.
The input circuits power supply is filtered and stabilized independently, in order to avoid any interference with the power stage, while 3 additional independent secondary circuits feed the low start, loudspeaker protection and bias reduction circuits. All the electronics is installed on nine fiberglass, 2.4 mm thick, double-sided printed circuit boards, featuring 120 micron thick copper paths, complying with military standards.
This power amplifier uses only top-quality components: 1% metal layer resistors, PP and PS capacitors, Cermet trimmers, relays with golden contacts, power resistors complying with military standards, IR diode bridges and selected Toshiba, Motorola and Hitachi active components.
From the aesthetics point of view, this device, for the most part, reminds of the preamplifiers design, since the machining processes employed are the same; however, some decorative elements have been added, such as the lower MOSFET banks, tilted in order to improve their aesthetic effect, the rear and front nameplate, made of black Plexiglas and reverse engraved, the chrome plated inserts of the heat sinks and the black chrome plated sub-base. The aluminium cover fits into a frame of rounded profiles continuing, as in the preamplifier, the front panel design line.
At SIAV 2013 show in Shanghai.
A-120X mono amps and A-60X stereo amp are available - price will be €25500 and €14500 incl Italian VAT (outside EU no VAT).
Look at the inside - beautiful! - both are using the same technology as the extraordinary good sounding A-300X.
And both can be compared to other brands costing up to 5 times more.
Bigger and more pictures of both at my picture site.
These Amps are gorgeous. Very well made in deed. Where can we audition them?
Only in Italy - they sell only direct to customer.
That is why the prices are so low - if sold in shops the prices will be much higher.
