Puma Cat
Yes, a chassis screw is where you would attach them; I bought brass screws, copper are also available but not necessary since these STIS terminals are brass themselves
Actually, the STIS terminals are copper.
This is helpful do you recall which cables you used to ground? I’d like to try the same. Thank you
You may not have seen the plating?
...10 minutes later....
Good grief, these Delta's absolutely smoke the PS Audio Prelude power cables!
I'm left to wonder what design characteristic of the Shunyata power cables brings the advantage here.I'll try not to think about it.
Oh, yeah…Maybe the Grandioso C1X would also benefit from a power cable upgrade.
