A humble hobbyist's review: Fosi Audio BT20A MAX
_theaudiofile
G’day!
I’ve been a lurker for a while and wanted to start giving back to the community, starting with some thoughts on the Fosi Audio BT20A MAX.
Full disclosure: Fosi sent me this unit to test, but they have zero control over what I publish. This is my unfiltered take.
TL;DR - Overall Rating: 8.2/10
The BT20A MAX is a capable Class-D amp featuring PFFB technology, an 80Hz High-Pass Filter, Bluetooth 6.0, and a neutral-warm sound. To push high wattage from a tiny chassis, Fosi utilised an active cooling fan to manage thermals. The faint fan noise and lack of auto-standby make it slightly fiddly for a near-field PC setup, but it performs exceptionally well in a living room environment. It has a few quirks, but the pros easily outweigh the cons and I recommend it.
Design & Setup
The BT20A retains the iconic black and orange Fosi aesthetic. It’s a clean, matte black front panel and a glossy top, contrasted by copper-orange side ventilation grills.
For the first week, I wired it into my bedroom desk setup, feeding it from my PC to drive my SVS Prime Bookshelf speakers using custom Canare 4S11 cables. For the second week, I moved it out to the living room to see how it handled a larger space.
It is important to note what this amp doesn't have: besides the dual RCA inputs, there is no built-in USB DAC or phono stage. My computer's internal DAC handled the Digital-to-Analogue conversion before the signal hit the Fosi. The SVS Primes are revealing monitors that can be bright and demand serious current. To ensure adequate headroom in both setups, I used Fosi's 48V/5A power brick.
Music and Movies Performance
The PFFB implementation means the amp delivers a flat, consistent frequency response regardless of the speaker's impedance curve. The overall signature is dynamic and mostly neutral, with a slight lower-midrange warmth that pairs well with the top-end energy of the SVS Primes.
  • Music Test: Starting with George Michael’s Careless Whisper, the amp's soundstage stood out. The iconic saxophone intro cut through with pure clarity without ever sounding piercing, and the lower-mid warmth gave his vocals a smooth texture. Moving on to Journey's Faithfully and Open Arms, I wanted to see how it handled Steve Perry’s vocals. Budget Class-D amps usually make these tracks sound shouty or fatiguing at high volumes, but the Fosi delivered a smooth. Finally, Eagles' Hotel California, the acoustic guitar plucks and intricate instrument layering had excellent separation, and that famous bass drum kick landed with real weight and authority.
  • Movie Test: I loaded up Dune to test pure dynamic range and burst response. The SVS Primes need serious current to deliver cinematic impact, and with the 48V power supply, the Fosi performed. During the flight scenes, the amp maintained a tight grip on the drivers. Switching to Ryan Coogler's Sinners, the amp did a great job rendering the tension-building atmosphere. The sudden dynamic swings and deep, thriller-style bass drops were punchy and fast, never dissolving into a muddy rumble.
Bluetooth 6.0
I am usually critical of wireless audio, but Fosi did a great job here with the Qualcomm QCC3095 chipset.
Streaming FLAC files from my phone via the LDAC codec provided stable wireless performance. The noise floor is low, and the audio fidelity is closely comparable to the wired RCA input.
Range is excellent, I could walk to the kitchen without the signal dropping. Latency is also well-managed, with no noticeable lip-sync delay when watching videos.
Bass Management
A major standout is the 80Hz High-Pass Filter. Flipping the switch stops the amp from sending frequencies below 80Hz to the main speakers, routing them to the subwoofer instead. This allowed the SVS Primes to play louder and cleaner in my 2.1 setup.
Considerations & Areas for Improvement
While the BT20A MAX sounds great, there are some considerations to note.
The Active Cooling Fan - Fosi included a fan to manage thermals without bulky heatsinks. While there is a faint hum noticeable from two feet away in a quiet room, it blends in once audio plays. It’s a practical solution, though a moving part always carries a long-term risk of wear.
Idle Power and No Standby Mode - The amp lacks an auto-standby feature and draws some power when idle. Unless manually switched off, the unit stays fully powered and the fan continues spinning.
Specifications
  • Amplifier Chip: Texas Instruments TPA3255
  • Power Output: 300W x 2 Max (Real-world continuous output into 8 ohms with a 48V supply is closer to 85-100W)
  • Architecture: Class-D with PFFB (Post-Filter Feedback)
  • Connectivity: Dual RCA inputs, Subwoofer Out, Passive Speaker Binding Posts
  • Internal DAC/Phono: None (Purely analogue inputs)
  • Wireless: Bluetooth 6.0 (Qualcomm QCC3095 chipset) with aptX HD, Adaptive, Lossless, and LDAC
  • Bass Management: Switchable 80Hz High-Pass Filter (HPF)
  • Idle Power Draw: ~15W
  • Cooling: Active internal cooling fan
  • THD: < 0.003%
Verdict
Sound Quality: 8.5/10 - Clean, authoritative, and free of typical Class-D load dependency issues. Handles vocals well with a pleasant lower-mid warmth.
Build & Quality: 7.5/10 - The aluminium casing, binding posts, and classic black-and-orange aesthetic feel premium. The active fan is a smart thermal solution for the size, even if it introduces a moving part.
Features: 9/10 - Dual RCAs, tone bypass, PFFB, stable LDAC Bluetooth, and an 80Hz High-Pass Filter.
Value: 8/10 - Flexible across different setups with a strong power-to-price ratio.
Final Thoughts: After two weeks of extensive testing, Fosi built an incredibly capable amplifier with the BT20A MAX. The PFFB technology proves they are listening to the audiophile community. It balances massive power with a small footprint, thanks to the integration of active cooling. If you are using it on a desk, you just have to manage the power switch yourself and not mind a faint fan sound in a completely silent room. However, tucked under a TV for a living room 2.1 system, it drives the setup with impressive authority and clarity.
