KingRT10
Using only say 50 watts, why does my 501's (Amps) totally blow my
MA2275 away in the low end department?
It's not even close to where you have to switch A/B.
It's a big enough difference, that you would swear that you had upgraded the speakers. Not the amps.
Should not 50 watts = 50 watts?
It's not as if the MA2275 was an inexpensive product either.
Is it typical for all tube amps to have a weak bottom end, compared to SS?
