Results 251 to 292 of 292
May 14, 2016, 12:40 PM #251
- Oct 2014
- 84
May 14, 2016, 12:55 PM #252
May 14, 2016, 01:01 PM #253
- Oct 2014
- 84
Re: Any Shindo 604 AlNiCo owners here?
Have you or anyone else here personally heard the WE horns he's using in a good system or (even better) in a Shindo system?
Curious to hear some unbiased feedback on the strengths/weaknesses of this approach versus the Latours.
Anyone know any WEstern Electric aficionados in the San Francisco Bay Area?
May 14, 2016, 02:06 PM #254
Ask at the lenco forum. Lots of WE knowledge over there from guys who are interested in audio and audio history and not...errrr....shopping.
May 15, 2016, 05:56 AM #255
- May 2016
- France
- 1
The shindo speaker is a great solution with good high efficency sound, smooth and open, natural etc...its the solution I had arrived to before going for the large western electric horns. The move from Atlec/JBL is not a simple one as ones foundations need to be reconsidered. When dealing with >110db horns that cover 50>85hz to 5000hz>5500hz in one go it challenges yet is rewarding. Have made horns for many around the world and they will all confirm this. A few are in California state. Not many of these systems on the planet...
All fun...
May 15, 2016, 11:44 PM #256
BTW, I'm now using super tweeters on my 604's with very agreeable results.
Craig
Listening Room: Shindo Vosne Romanee and Haut Brion, Shindo Alnico 604's, Fostex T90A's, slate Lenco TT, Schick tonearm, Bob's Devices 1311, PS Audio DirectStream, Naim CD5, Sonos, Shindo IC's and wire, WE wire
On loan - in a buddy's man cave: Almarro a205a, Sonos, Rega Juras
HT: McCormack MAP1 and HT3, Manaplaner CC2 and MC1's, REL, Cambridge DacMagic, Sonos
May 16, 2016, 06:16 PM #257
- Jan 2014
- 115
Craig- love the finish on your 604's. I'm sure it sounds wonderful. Nice that you can control the level of that super tweeter.
May 16, 2016, 10:33 PM #258
Thanks. You noticed the attenuators which coupled with various value capacitors allow experimentation and better integration with the 604's. A while back, you told me that the 604's were probably nowhere near fully broken in. In addition, it was likely that the new tubes in the Haut Brion needed further burn-in. Whatever the reason, the combo wasn't yet producing the high frequency I was told to expect, and these Fostex units got things where I like them. They may be a short term solution, but they sure sound nice as is.
Craig
May 19, 2016, 02:26 PM #259
Sorry Don, it was Bill (loop4fun) that told me that the 604's weren't broken in yet. I momentarily got confused because you both have 4's in your user names. I must be easily addled!
Craig
June 12, 2016, 06:28 PM #260
- Jan 2014
- 115
I'm getting stands built for my Altec Valencia 846A's. Can Shindo speaker owners share the approximate height the horn is off the ground. I am liking my Altec's about 8" off the ground now. Because my grills are on there, I haven't checked to see if my horns are at ear level. System: WT GTA, TSD-15 SFL, A23 Homage T2, V/R, Dy'Quem's, Lignolab rack. Cheers -Don
June 13, 2016, 10:35 AM #261
The 604 horns are about 34" high which is just about perfect ear height when I'm on my listening sofa. Imaging usually puts sound sources slightly above the horn height.
FWIW: The Fostex super tweeters are on the center top of each speaker. If I could mount them more at ear level, they would probably disappear even more than they already do, which is nicely.Craig
June 13, 2016, 11:08 AM #262
- Jan 2014
- 115
Thanks Craig. I think getting my horned up to 32" will be near ideal. Of course I have the play in my chair, but I find my sweet spot is my ear being no more than 32" off the ground. (-:
October 24, 2016, 02:41 PM #263
- Mar 2016
- 161
Thats a great speaker!
June 26, 2017, 08:14 AM #264
- Jun 2017
- 1
Bill,
I am new to this forum and I appreciate reading posts like yours as they come across straightforward. Can you comment on any experience you may have had with room placement - most of the pics I have seen show the Latour speakers very close to the rear wall and apparently even side walls.
Francis
June 26, 2017, 11:58 AM #265
Francis, welcome to the forum, thank you so much for joining.
June 26, 2017, 12:52 PM #266
October 27, 2017, 08:55 PM #267
Francis,
Until Bill responds, I’m happy to chime in. From memory, my Latour 604s are around 24” out from the front wall and nearly 30” from the sidewall, 7.5 feet apart and slightly toed in to a point behind the listening position 10 feet away so the inside panels are just visible. The speakers rest on 2’x4’ plywood, until I make permanent wood platforms, per the dealer’s recommendation. Better to sit on wood than cement, I’m told.
My situation requires placement closer to the front wall, but they do sound great several feet out too. When placed in a much larger room (25x40’), many feet away from all walls, they opened up and breathed nicely, despite a crossover mis-setting that was later fully fixed by Shindo. However, the reflective effects of a smaller room lend atmosphere (excitement) and bass reinforcement to many recordings, provided the reflections and resonances are controlled. The mid/tweeter horns are directional and that helps to control HF reflections.
On that note, behind the speakers I have three 2’x4’ wood framed bass traps filled with 4” thick mineral wool batten covered with linen. The right side wall has three similar absorbers with 2” batten to negate mid and high frequency reflections from the plaster and cement.
Not that you asked, but for context, my room is kind of trapezoidal, with the front wall the shortest (15 feet or so), the back wall longest (21 feet), side walls asymmetrical (14 and 16 feet) and 4 for wide passage ways abutting the back wall. 11 foot wood and beam ceilings. All walls are plaster over solid adobe (mud bricks), except the back wall which has a very large window/ sliding door. Floor is finished cement.
more than you asked for...Craig
October 27, 2017, 11:07 PM #268
Update - my 604s had a crossover setting issue that limited their HF response. Shindo fixed this. At this point, the speakers are broken in and I no longer need the super tweeters.
Craig
March 14, 2018, 10:14 AM #269
- Mar 2016
- 161
Supertweeters are unnecessary with Altec 604. See the freq. ressponse curves!
March 14, 2018, 10:45 AM #270
That’s what you would think! Of course I looked at the response curves before purchasing the speakers. The problem arose when the speakers did not perform as anticipated. It took them over a year to break in. It’s possible that the attenuators did not need to be adjusted, but I was not prepared for the length of time it took for them to start to perform above 10,000 Hz. At this point, they can sound absolutely magical. I’m amazed at the imaging and the size of the soundstage. They can be delicate and brutish. Of course they’re not perfect for every type of music, congested poorly recorded rock in particular, and their placement and the room make a big difference. Normally reside in a billiard room. Some people might call this a profane use of such a nice system. I however, there is not a god to which I bow. I have reveled in listening while playing pool, but I have no listening chair per se. I’m one of those people that likes to also get up and walk around or boogy to music. However sometimes I move them. They sound best without a doubt in our 25 x 50’ living room/kitchen. They open up and create an effortless and large soundstage, through which the horns project all of the impact in detail that I would want.
March 16, 2018, 05:53 AM #271
- Mar 2016
- 161
Any luxury product in that price region could be expected to work at least within specs. We are talking about a heavy moded speaker which distincts itself from the mass production model not only by the modification but by its price. If I bought Rolls Royce than I would expect the company to have a quality control inspection plan to assure that every product that leaves the factory works flawlessly. If that may not being happen for some reasons, at least the local dealer should check before delivery to the customer that it works properly. In your case, it seems that both have failed in delivering an unfaulty product.
March 16, 2018, 06:19 PM #272Craig
March 16, 2018, 08:34 PM #273
"walter" has a grudge against Shindo and Keith at A23. No sure why. I would ignore is opinion as it seems to me he is just trying do do damage to both brands.
Walter acts like a ....Chris
Garrard 301, SME 2012r, EMT TSD15, A23 T2 Hommage SUT, Shindo Montille, Shindo Aurieges, Shindo ICs and Auditorium Speaker Cables, Auditorium A23 Hommage 755a Speakers.
March 18, 2018, 12:18 PM #274
- Mar 2016
- 161
"Cucumber_jones" has a grudge against Shindo and Keith at A23. No sure why. I would ignore is opinion as it seems to me he is just trying do do damage to both brands.
How do you know about other peoples behaves hundreds miles away from you and never met personally?
Isnt this all obscure speculation from your side?
Why do you always react personally offending to other forum members when someone is critical with "your" Shindo brand?
I'll tell you something. You have become personally identified so much with this brand, that it hurts when someone is critical to it.
And thats what can be called a true Shindo- fanboy.
I suggest to ignore your opinion as it seems to me he is just trying do damage to both brands with his fanboy behaviour.
How about this, Chris? Are you the new forum master here on this board to advise other members how to behave?
March 18, 2018, 12:37 PM #275
But what is your criticism, Walter? If you have something specific to say about your experience with Shindo gear and or service, please explain in detail. Otherwise, you are just slandering Shindo with vague accusations. Given that this is the most micro of micro brands, with some amp productions in probably the single digits, and this is one of the only public sources of information about the brand, your comments can unfairly do significant damage.
For context, I’ve spent probably close to six figures with Shindo dealers. I have sold much of that gear. So I have significant “skin” in the game and an informed opinion. Am I a fan boy? Yes and no. I have had some criticisms of Shindo through my period of ownership, so I’m not going to say everything is perfect. That is only natural for a rational person. If you want to have a fair and open discussion about your experiences that is one thing. I’m sure that the reps don’t love that, but what can you do? If you sell expensive things, you have to accept criticism of your products and your service. although it seems contrary to prevailing hi-end audio tradition, the customer IS the one in charge and those guys selling the stuff are working for you and your business. You don’t owe them anything EXCEPT fairness and honesty in your dealings.
One thing I am a fan of is the level of service and degree of commitment from the Shindo representatives. From J. Halpern, Matt, Keith - they are all passionate about what they do and could certainly make more money by sacrificing their vision for the brand. They are professionals and unfounded criticism hurts them professionally. That’s not nice.
March 18, 2018, 01:20 PM #276
Chris
March 18, 2018, 01:24 PM #277
- Mar 2016
- 161
Personal
March 19, 2018, 02:49 PM #278
- Mar 2016
- 161
Whos that guy?
After sending me personal emails and not having received any replies from my side, now nothing but pure speculation comes to your mind?
Again my question to you: Why do you always have to become offending on a personal level when it comes to objective criticism?
You may know that your method trying to offend other forum members have been executed by the nazis as well. So you are not only intollerant and a fascist, you have proven to be a real nazi. Congratulations, Chris!
March 19, 2018, 04:24 PM #279
Because I am sick of watching you slander two brands I am a nazi? That is the funniest thing I have ever read. Nice work losing what ever credibility you may have had.
Chris
March 19, 2018, 04:46 PM #280
- Mar 2016
- 161
I strongly pled to the forum hosts to remove you from this forum because you offended the forum rules many time by being personal indulgent to other forum members and are unable to tolerate different opinions from forum members. Instead, you try to kill other memebers by spreading speculative misinformations about them.
You should post no longer here in this "friendliest forum on the internet". Your behaviour here is contrary to that statement and absolutely untolerable.
March 19, 2018, 05:20 PM #281
Just stop your slandering of shindo and a23. That’s the real issue here.
Chris
March 19, 2018, 09:26 PM #282
- Mar 2016
- 161
You will be banned from this forum anyway. Must rub your cucumber anywhere else. Sorry for that phrase.
March 19, 2018, 09:40 PM #283
We will see. I can't see anywhere that I have been systematically writing posts to harm business.
Sent from my iPad using TapatalkChris
March 19, 2018, 10:18 PM #284
OK boys...let’s behave. Enough of the name calling.
March 19, 2018, 11:12 PM #285
Oh boy. the Shindo thread never changes.... Sigh...
I loved Shindo amps and pre .. still one of the top 3 best sounds I ever heard in my room with my Tannoy Westminster. They were singing like they made for each other. Well, All the Shindo dealer and distributor wasn't happy to hear about my find with their NON approved speakers matching with Shindo ....while Shindo in Japan saying it's perfectly fine with matching with my speakers ! .. Hahahaha ( Now I can laugh about it )
Anyway, Chris. Anything change on your set up? Do you still have the LM and Altec speakers?Paul
March 20, 2018, 12:19 AM #286
- Mar 2016
- 161
Discussion Board - Helpful Hints
Netiquette - Remind students of proper “netiquette” - a respectful code of conduct when communicating online. Some netiquette tips:
• Be very clear and stick to the point when writing posts
• Check for spelling/grammar errors and do not use slang
• Be respectful of others with appropriate choice of language
• Challenge others, but avoid personal attacks
• Be careful when using humor online – it can easily be misinterpreted
March 20, 2018, 11:49 AM #287
Chris
March 20, 2018, 12:47 PM #288
- Mar 2016
- 161
Cucumber,
maybe you are too dumb to realize what behaviour you are acting here. Acting as a true Shindo fanboy, who is intollerant to other forum members opinions and expectations. Playing here the little Nazi dictator who tries to disparage every people who has his own opinion, you have proven that already. So in fact its your reputation that degrades continually. But your cucumber will be banned anyway. The forum mods are already notified what kind of regime you are acting here.
March 20, 2018, 12:51 PM #289
Chris
March 20, 2018, 02:22 PM #290
- Mar 2016
- 161
What are u blathering bout, cucumber?
March 20, 2018, 07:10 PM #291
- Jul 2015
- Golden, CO
- 858
Okay. I have to step in. Please don’t ever again use the word or term “Nazi” or label a participant on an audio forum as a “Nazi.” I and am sure others find this reference and use of this term to be highly offensive for obvious reasons. I have close friends whose family members lost their lives in the Holocaust at the hands of the malevolent Nazi Regime. This is a hobby, for pete’s sake. Grow up, please!
March 20, 2018, 08:05 PM #292
I agree. Walter grow up!
Chris
I never really noticed that much of a difference playing CDs but with streaming it can be quite a bit.
Lumin U2 Mini
