Yes, Virginia transports do make a difference, usually
Mr Peabody
St. Louis, MO, USA
In my experience transports have always made a difference on sound quality. I say "usually" because someone I trust to know and hear any difference had an older Levinson DAC with a re-clocker in the input stage and he says transports didn't make a difference for him with that DAC. I attribute that to the re-clocking.
When I first got my hands on an outboard DAC I played with CD players as transports. I was shocked to hear the character of my Krell CDP imparted itself on my DAC. I had an inexpensive TDK CD player/recorder hooked it up to the same DAC and it sounded anemic like it couldn't drive the DAC.
One of my most incredible sounding matches, synergy, was an EAD transport hooked up to an Audio Note DAC. I loved that combo. Maybe a bit too romantic but it was so nice to listen to. The EAD died and I couldn't get it fixed. I moved on from there to a single box T+A player. 180 right? Just a sidenote I used that T+A to show another friend that sources makes a difference. He had a very expensive system and using like a $1200 player, the T+A showed him he needs to do some upgrading.
I found the same with streaming transports. I started with HEOS, then Node, then a $4k streamer. My goal was to find a combo that matched or beat my former #512 Levinson SACD. My Aurender got me there which I purchased after hearing it not being happy with the former $4k unit.
I'm amazed at how many people still say "it's only 1's and 0's". I've learned not to get involved in trying to convince them. As most things in audio you have to try; and hopefully learn.
Feel free to share one way or the other. Like my friend my experience may not be yours.
There’s a lot going on in transports to get from pits on the disc to formatted S/PDIF into a DAC. My first experience with this was a Rega Planet CD player feeding a Benchmark DAC, and a Marantz CD- 54 (I think, it’s been a long time) feeding the same DAC. The two transports sounded different. The Marantz had better imaging and dynamics. The Rega was warmer for some reason. This was the start of my ‘everything matters in digital’ journey. Even when a lot of pundits said it didn’t matter, because technically it shouldn’t matter.
I replaced a skipping Cambridge transport, which I think was my weakest link, with a TEAC 507T. Besides the no-skipping issue, the TEAC sounds better, going into the PrimaLuna DAC through a Cardas Clear RCA.
We just got that transport. The TEAC is awesome.
- and it's a cute little thing.
I also like the old-school power toggle switch.
It gives me some sort of satisfaction, like I've achieved something more than just pressing a button.
That's my review. Can I get a gig with TAS now?
Recently, I purchased a Bricasti M19 SACD transport for a few reasons. I'm an all digital guy...I wanted to get back to having an option to spinning CDs and SACDs in their entirety (even though I have over 2,500 discs on my music server I don't seem to listen to an entire disc), I'm a loyal fan of Bricasti and wanted the synergy with the rest of my stack, and I was intrigued by their implementation of native DSD into the DSD chip of the M1 Series II DAC via I2S through RJ45.
Most definitely the best sounding transport I've owned (have also had BMC, Marantz and some others [which all had different sonic signatures] though none paired with my Bricasti components). Not just SACD, but the CDs also have a great sound. Perhaps due to dual mono end-to-end...who knows?
