Installed this morning, and as soon as I turned it on I thought, “This is good.” Pretty much the same thing I thought when I first heard the S5 in my system.
Anyway, the pre has been playing all day. Obviously, it needs some burn in time, but it certainly is the equal of the XP-20, and that was an XP-20 with the Revelation Audio umbilical.
I like this new, longer umbilical with the aircraft grade plugs and connectors. The drawback to the RA DB-25 connector was it had to be screwed in with a small screwdriver. Trying to reach behind the XP-20 to install this cable was painful. The aircraft Canon plugs are simple to install from the front.
Anyway, I have the power supply on the floor under the rack, and the preamp on brass footers. Plus, I installed a ground cable between the pre chassis, and the Triton ground bus. With the 20 I had the ground on the ps chassis.
I will let it play nonstop all weekend, and I might take Friday off so that I can start evaluating the XP-22 tomorrow night. Right now it is really sounding good, but I can’t give a definitive difference between it and the XP-20.
New layout
XP-20 with RA umbilical.
