With speaker cables, how long is too long?
joeinid
Super Moderator
NY
Is there an optimal length for speaker cables? Do you run 20' or 30' cables? Longer?
Obviously they need to be long enough to actually connect the speakers. :) :scholar:
The shorter the better! I wouldn't buy cables longer than 8 feet. I can hear differences between 8 and 10 feet and I'm talking about hi-end cables! :snicker:
I agree the shorter the better & <8ft is best. I use 2.0 mtr sc's which is fortunately enough for my setup. And that has allowed me to upgrade to Jorma's flagship Statement cables. The longer the length required, obviously cost goes up and then you're potentially faced with the need to compromise on the level of cables you buy such as going for the next model down, or look 2nd hand.
My Everest loudspeaker cables are 8ft long. The downside with them is that they are terribly rigid and therefore complicated to position.
Transparent does not make any speaker cable under 8 feet. I know they have experimented with shorter distances and their research showed that they didn't work as well. Maybe some one can give the exact details why? I know I read it somewhere years ago but I didn't memorize it...
Ive never heard that before, so I'm just as curious as you..
More importantly, each cable should be exactly the same length down to the millimeter!
Like many I prefer short SC and longer interconnects for 3 reasons. 1) sound quality. I want as little between my speakers as possible and I find it better with amps low to the ground and components off to the side. 2) asthetics 3) cost. Usually speaker cable costs more than interconnects, especially in the Transparent line.
IMO - the acoustic wave-launch into the room, and proper reception of it at the listening seat is most important. Once you know that, only then can you decide what to do about cables & lengths.
For example, I would not recommend damaging the acoustic wave-launch into the room, just so you can keep a certain cable or cable length. Those cable differences are MINISCULE when compared to best room/speaker interface.
Okay, I might be able to get my speakers cables to within 1mm. Now what do I do with my ears? I am pretty sure they are not exactly symmetrical. :D
