Wireworld Platinum Electra 7 Power cord
MM622
Does anyone knows so far how many generation of Wireworld Platinum Electra Power cord has?
Because the current model is 7 or
Wireworld Platinum Electra 7, but the cable and packing does not show "7". So how do I know if the product is 7 or previous old model?
Which is the best place to use this cable : Per-amp or power-amp?
THX
You could always ask for the serial number and contact Wireworld. They are extremely helpful and shouldn't mind at all helping determine the series.
As for placement, Wireworld recommends starting downstream and working upstream, so the first place they would say to put it is the power amplifier.
I have all my equipment hooked up with platinum Electra 7 and the only real way to determine is serial number.
Great power cords btw. Unfortunately I can’t comment on which device to put it on as I put all 6 in at the same time. My guess would be source first but that’s how I think about all improvements
