That's real.
The difference are in the system and the room.... and the products...It depends ...
Bite on this: SACD vs Vinyl (pros and cons?) | Headphone Reviews and Discussion - Head-Fi.org
There are no comparison between CD and vinyl.
Vinyl has a better sound than CD.
There is no doubt.
And HD streaming is the last thing I will buy...to listen music in my system
And what is your system, please ?on 'your' system, perhaps ! But to make an absolute statement that applies to all.... NO WAY !!
Envoyé de mon Note 9P en utilisant Tapatalk
what's the point. Its like asking the make and type of wine glass they drink from when they cant tell the difference between Two Buck Chuck and Chateaux Mouton Rothschild![]()
You have my system in my profile....what's the point. Its like asking the make and type of wine glass they drink from when they cant tell the difference between Two Buck Chuck and Chateaux Mouton Rothschild![]()
There is no doubt.
I have a/b tested a recent time cd and from the same a vinyl and played them side by side at exactly the same measured volume and from this my conclusion is that is almost no difference between the two. That moved me in the direction that IF there are any differences, the mastering must be different. Hope this helps somewhat forward
